OT monitor installation Windows 10
Postby _Vera » Fri May 03, 2019 8:30 pm
I tried to install OTmonitor.exe and in a second attempt OTmonitor.zip (after unzip) to launch in Windows 10.
I get a warningscreen: software not for this version of Windows. Also tried comptability to change and with Admin rights, but the utilility will not start.
What am I missing here?
_Vera
Re: OT monitor installation Windows 10
Postby Rutger » Mon May 13, 2019 6:08 pm
2 weeks ago I reinstalled my HA server to Win10. and got the same warning. Tried all options that are giving online, like disabling Smartscreen, create a new admin account, Sideload apps, compatibility mode, etc, but it's still giving the warning. Last weekend I've installed the same Windows build in a virtualbox environment and without having other installations done, otmonitor is working fine here.
I odn't have a solution (yet) for the current HA system except running the same Win10 build in a virtualbox.
Rutger
Postby Edwin2008 » Sat May 18, 2019 7:46 am
W10 has multiple versions, perhaps that's why. Also the installer has a version check perhaps some wrong setting during creation?
** edwin **
Edwin2008
Postby hvxl » Sat May 25, 2019 8:06 pm
Might this be a 32<->64 bit issue? What happens if you try the 64-bit version of otmonitor: http://otgw.tclcode.com/download/otmonitor-x64.exe
Postby Hussar_303 » Sun May 26, 2019 5:33 pm
I swear, every single piece of software out there has issues with Windows 10... the only ones that haven't are the ones which were engineered under/for Win10 or that were fixed fast enough by the developers so that the users wouldn't notice :lol: if you do want to keep that OS, then check the version compatibility, and if it doesn't do the trick, then run it into a virtualbox system as Rutger said.
If you haven't bought Win10 but got it with your computer or something, then... use another OS! Anything will do the trick: Windows 8.1, most Linux variants...
Hussar_303
Postby Rutger » Sun May 26, 2019 6:56 pm
The 64 bit version doesn't solve the issue. Same "this app can't run on your pc" popup even when trying every option from the compatibility options.
Rutger
Postby Hussar_303 » Mon May 27, 2019 6:14 am
Rutger wrote:The 64 bit version doesn't solve the issue. Same "this app can't run on your pc" popup even when trying every option from the compatibility options.
Okay, thanks for the feedback! Then, Wine/virtualbox it is...
Hussar_303
Postby Rutger » Mon May 27, 2019 7:24 pm
Got it working now directly on my HA system. I've no changes made, but I saw a different in file size. For some reason some downloads reaches only 1 MB instead of the full 5.9MB. I never have seen this, but the file icon was missing as well.
Now it's all working again.
Rutger
Postby hvxl » Mon May 27, 2019 9:01 pm
The size is mentioned on the download page for a reason ...
cron
