Toon for Android
Re: Toon for Android
Postby RoadXY » Thu May 30, 2019 7:11 pm
anconakip wrote:
_Arjen_ wrote:It is 10080
Nope. Sorry. The the app say to me: pagina niet gevonden op apparaat.
And if i do 10800 the iT says: geen reactie van apparaat.
Could be an issue with your Toon.
What kind of output does:
http://IP-OF-TOON:PORT-OF-TOON/happ_the ... mostatInfo
provide?
RoadXY
Postby bjorker » Fri May 31, 2019 9:35 pm
Can it be that your toon ip address has changed after the upgrade/reboot.
Happened to me once.
Sent from my moto g(6) plus using Tapatalk
bjorker
Postby mAiden » Sat Jun 01, 2019 6:42 am
Then enter a static ip for Toon in your router. As a result, the DHCP server will always distribute that ip.
mAiden
Postby hanplo » Thu Jun 06, 2019 9:42 pm
Toon for Android and TSC Toon Mobiel does not give gas value, but does provide electricity. Toon himself gives gas value. Does anyone have a solution.
hanplo
Postby RoadXY » Fri Jul 19, 2019 1:37 pm
As Fabian isn't responding anymore I've disconnected my Github with his.
The new issue url is: https://github.com/Inversion-NL/Toon-An ... new/choose
I've updated the first post of this thread also.
RoadXY
Postby estate » Wed Oct 23, 2019 1:48 pm
Hi :)
As of yesterday I own me a Toon and now landed on the setting up to use it from the web.
I downloaded your app and if I connect with the internal IP (192.168.-.- range and port 80) the app works like a charm and I can control and view Toon, but..... when I enter the outside IP (the one my provider gave me) I get no connection, I tried ports 80, 10800, 10080 but nothing works.
Then I suddenly reminded that if you want to connect to something from the outside to the inside network you need to use port forwarding, at least that was the case years ago when I went to school regulairly :)
My question therefore is, do I need to port forward the Toon and which port and specifically which protocol do I use, TCP or UDP ?
Who can give me the working answer and is willing to support me on this ?
estate
Postby WickedMaster » Wed Oct 30, 2019 12:54 pm
You indeed have to forward a port to reach your Toon from the outside. You can, for example, forward port 10080 (TCP) to your Toon.
WickedMaster
Postby mAiden » Wed Oct 30, 2019 9:27 pm
Forwarding on port 80 is enough, that port is also open on iptables.
Then add you're extern IP ad the config file in the app, and set port to 80.
You can test the connection on you're mobile network (3g or 4g)
mAiden
Postby RoadXY » Thu Dec 05, 2019 2:27 pm
0.5.7 is released to alpha:
Added navigation drawer
Added Graphs for elec and gas
Setting for double tariff
Different icons for hot water and modulation levels
Aparte icoontjes voor warm water modulatie niveaus
m3 to litre (https://github.com/fabianblom/Toon-Android/issues/34)
Added units to refresh settings
Added 5 and 15 min (https://github.com/fabianblom/Toon-Android/issues/36)
Clicking gas or elec cards wil take you to the graphs
Bug fix: deselect program when using the + or - button
Please let me know if there are any issues.
RoadXY
Postby TheHogNL » Thu Dec 05, 2019 2:51 pm
How can I get into the alpha testing?
Postby Toonz » Thu Dec 05, 2019 3:10 pm
ik zie alleen de 0.5.6 beta
Postby RoadXY » Thu Dec 05, 2019 3:19 pm
TheHogNL wrote:How can I get into the alpha testing?
PM me your mail adres which is the Play Store account on your phone so I can add you to the alpha testers.
RoadXY
Postby RoadXY » Thu Dec 05, 2019 3:20 pm
Toonz wrote:ik zie alleen de 0.5.6 beta
Currently only released for for alpha testers.
RoadXY
Postby yjb » Thu Dec 05, 2019 10:47 pm
I'm on 0.5.7 but my "current gas usage" is always 0.
For GAS usage, the charts are empty "no chart data available"
The strange thing is that the total of today is displayed (and correct).
getdevices output:
"dev_3": {
"uuid": "8535fd22-4500-45bb-8852-f5c7160a5c90",
"name": "HAE_METER_v3",
"internalAddress": "3",
"type": "HAE_METER_v3",
"supportsCrc": "1",
"ccList": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
"supportedCC": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
"nodeFlags": [],
"IsConnected": "1",
"HealthValue": "10",
"DeviceName": "HAE_METER_v3",
"CurrentSensorStatus": "UNKNOWN"
"dev_3.1": {
"uuid": "d776e6d1-24e5-4b4e-8d89-2c68735489b3",
"name": "HAE_METER_v3_1",
"internalAddress": "3.1",
"type": "HAE_METER_v3_1",
"supportsCrc": "0",
"ccList": "5e 59 85 8e 3c 3d 3e",
"supportedCC": "5e 59 85 8e 3c 3d 3e",
"nodeFlags": [],
"CurrentGasFlow": "7.00",
"CurrentGasQuantity": "2115186.00",
"DeviceName": "HAE_METER_v3_1",
"CurrentSensorStatus": "OPERATIONAL"
"dev_3.2": {
"uuid": "a85b3097-3076-45bf-9ab1-7f671dc13f5b",
"name": "HAE_METER_v3_2",
"internalAddress": "3.2",
"type": "HAE_METER_v3_2",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_2",
"CurrentElectricityFlow": "NaN",
"CurrentElectricityQuantity": "NaN",
"dev_3.3": {
"uuid": "aacf62a8-80d5-4061-885a-d27d4c7c2162",
"name": "HAE_METER_v3_3",
"internalAddress": "3.3",
"type": "HAE_METER_v3_3",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_3",
"CurrentElectricityFlow": "0.00",
"CurrentElectricityQuantity": "2291014.00",
"dev_3.4": {
"uuid": "0cef5b2b-7272-4143-906f-59b284070bb4",
"name": "HAE_METER_v3_4",
"internalAddress": "3.4",
"type": "HAE_METER_v3_4",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_4",
"CurrentElectricityFlow": "460.00",
"CurrentElectricityQuantity": "1607322.00",
"dev_3.5": {
"uuid": "eb6ba2f9-558d-4944-b238-258a70115c77",
"name": "HAE_METER_v3_5",
"internalAddress": "3.5",
"type": "HAE_METER_v3_5",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_5",
"CurrentElectricityQuantity": "919657.00",
"dev_3.6": {
"uuid": "efe14178-7bdc-4d14-b1fa-32a5deaf4d6a",
"name": "HAE_METER_v3_6",
"internalAddress": "3.6",
"type": "HAE_METER_v3_6",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_6",
"CurrentElectricityQuantity": "2324772.00",
"dev_3.7": {
"uuid": "22397305-82e3-46c1-b0f0-05dbe3263f30",
"name": "HAE_METER_v3_7",
"internalAddress": "3.7",
"type": "HAE_METER_v3_7",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_7",
"CurrentElectricityQuantity": "430359.00",
"dev_3.8": {
"uuid": "e0a42332-622a-43a4-bbf7-c516ef5f8745",
"name": "HAE_METER_v3_8",
"internalAddress": "3.8",
"type": "HAE_METER_v3_8",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_8",
"CurrentHeatQuantity": "NaN",
"dev_settings_device": {
"uuid": "d6d5ce1d-2055-40f4-b9b3-991f1a8f6848",
"name": "settings_device",
"internalAddress": "settings_device",
"type": "settings_device"
yjb
Postby RoadXY » Thu Dec 05, 2019 11:42 pm
I've fixed that in the upcoming version
RoadXY
PreviousNext
Return to Toon external control
