Toon firmware - update script
Postby mAiden » Mon Jun 03, 2019 8:44 am
hansgrave wrote:Last week i run the update script on two Toons: once from the second last firmware and once from firmware 4.16.8.
The update from the second last firmware went smooth but by the update from firmware 4.16.8 the proces hang at some point.
Following the instructions from mAiden did the job to get a working Toon back, thanx.
No problem. Fine that my instructions help you :)
mAiden
Postby Ojp » Mon Jun 03, 2019 7:38 pm
Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. It worked as a charm!
I am not sure to upgrade to version 5 or higher. Are some interesting features to take the risk?
Adios.
Ojp
Postby TerrorSource » Mon Jun 03, 2019 10:43 pm
Ojp wrote:Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. I worked as a charm!
Adios.
Why not upgrade to the latest firmware? Booting the Toon/Boxx is a bit faster with 5.x.x firmware.
TerrorSource
Postby Toonz » Tue Jun 04, 2019 8:24 am
Adios.
My 2 cents: I read a lot of complaints about delays when taking the Toon out of dim state with firmware 5 on a Toon 1.
I personally prefer 4.x on a Toon 1, feels faster.....booting speed is less relevant for me.
If you have a Toon 2 I would certainly move to version 5 due to better Wifi performance.
Postby adval40 » Thu Jun 06, 2019 4:53 pm
yesterday i have updated my firmware with the update script
update failed
i saw into the logfile disk full
which files may i delete ?
adval40
Postby TheHogNL » Thu Jun 06, 2019 8:52 pm
cleanup /mnt/data/update/*
Postby adval40 » Thu Jun 06, 2019 8:57 pm
this dir is empty
adval40
Postby TheHogNL » Fri Jun 07, 2019 5:40 pm
Then please check /HCBv2/tmp/opkg-cache
Postby adval40 » Fri Jun 07, 2019 6:10 pm
I has remove the files in this cache dir i have 30mb free
after reboot he did'nt start up
the display hangs in the boot process
no ssh connection possible
adval40
Postby adval40 » Fri Jun 07, 2019 6:40 pm
I will try make a new connection via serial
adval40
Postby TheHogNL » Fri Jun 07, 2019 7:04 pm
Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
What was the previous firmware you where on and to which firmware where you updating to?
Postby whizzz63 » Sat Jun 08, 2019 10:40 am
TheHogNL wrote:Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
I had the same problem. Still trying to repair via a serial connection....
whizzz63
Postby TheHogNL » Sat Jun 08, 2019 1:50 pm
From which firmware?
Postby whizzz63 » Sat Jun 08, 2019 3:00 pm
5.5.7
whizzz63
Postby TheHogNL » Sat Jun 08, 2019 3:13 pm
That is the to firmware I guess :-) I mean what was the firmware before you started the update
PreviousNext
Return to Toon Firmware
cron
