Toon app: ToonStore
Edwin66
Re: Toon app: ToonStore
Post by Edwin66 »
Heb helemaal geen TSC tab in instellingen
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plugs | some TUYA stuff |
I'm not a programmer, just wish things work MY way
then you have a too old version of the resourcefile I think.
You can download it here manually: qutility.nl/resourcesfiles/ , select the right file for your firmware (qb2 = toon 1 , nxt = toon 2).
Unzip it and copy the rcc files to /qmf/qml
Or alternatively downgrade the ToonStore to an older version.
In both cases you will need access to your Toon, which isn't going smooth as I read in the other topic ;-)
Edwin66
Post by Edwin66 »
I might need some help with this ;)
The requested URL /resourcesfiles/ was not found on this server.
mAiden
Post by mAiden »
Which version is your Toon on? Resource files work from 4.16.8
http://qutility.nl/resourcefiles/ is the link where you can find them.
Edwin66
Post by Edwin66 »
i believe its firmware 4.19.10
sorry , made a type in the url, mAiden already provided you the correct one
Edwin66
Post by Edwin66 »
So.. now I did a 'wget http://qutility.nl/resourcefiles/resour ... .19.10.zip' then unzipped and moved the rcc files to /qml/qmf
That should do the trick?
btw. Is it possible to set an easier to remember password on the Toon?
TerrorSource
Post by TerrorSource »
Edwin66 wrote:So.. now I did a 'wget http://qutility.nl/resourcefiles/resour ... .19.10.zip' then unzipped and moved the rcc files to /qml/qmf
Why didn't you do a "sh update-rooted.sh -f" ? That will fix everything for you automatically.
We decided to stop support of older firmwares (everything below firmware 5) when publishing new apps or updates of existing apps.
This will greatly simplify the effort needed to create and maintain the installation scripts.
Also QML apps can start making use of functionality which is only available on firmware 5.
This means that existing apps can still be used on older firmwares but updates of apps and new apps will only become available on firmware 5.
Edwin66
Post by Edwin66 »
Damn... I can't get my Toon upgraded to any higher version then 4.19.* :(
Edwin66
Post by Edwin66 »
Didn't work.
Post by TheHogNL »
On your toon using putty:
curl -Nks https://raw.githubusercontent.com/ToonSoftwareCollective/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
sh /root/update-rooted.sh -u
That should update your toon. If not paste the logs.
Edwin66
Post by Edwin66 »
There is something wrong with the VPN connection on my Toon.
Post by TheHogNL »
Edwin66 wrote:There is something wrong with the VPN connection on my Toon.
Run this to check why your VPN isn't starting:
/usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Maybe your VPN key is withdrawn. If so, contact me PM. I do have some old not working toon's from which you can have the VPN key from for a small payment.
a new version of ToonStore (4.0.0) is available in the ToonStore.
This is the last app store update in a row to move all settings files to the /mnt/data/tsc folder.
This was all to prepare for our move to GitHub with all apps.
The new upcoming TSC scripts will install apps directly from Github, without making use of the ipk packages and signature keys anymore.
The big advantage of GitHub is that everyone can easily contribute to further code development for all apps.
The downside is that we had to drop firmware 4 and lower compatibility.
More to come on this one, stay tuned…….
Changelog:
- settings are now stored in /mnt/data/tsc/toonstore.userSettings.json
- app is only firmware 5 compatible. Support for older firmware has been dropped.
- toonstore apps can only be installed via the supporting TSC scipts on firmware 5
Therefore support for signature keys (needed for app installations on older firmwares) has been dropped as well.
