Hacker !!!!!!
Forum about all other NON Home automation stuff can be placed here....
Hacker !!!!!!
Postby Verkenner » Mon Oct 14, 2019 7:29 pm
A hacker with IP 23.225.177.107 is trying to login to my Homeseer. :-(
okt-14 19:31:20 Web Server Web Server login failed from: 23.225.177.107 User: user
okt-14 19:31:20 Web Server Web Server login failed from: 23.225.177.107 User: admin
okt-14 19:31:19 Web Server Web Server login failed from: 23.225.177.107 User: admin
okt-14 19:31:19 Web Server Web Server login failed from: 23.225.177.107 User: support
okt-14 19:31:18 Web Server Web Server login failed from: 23.225.177.107 User: user
okt-14 19:31:18 Web Server Web Server login failed from: 23.225.177.107 User: username
okt-14 19:31:17 Web Server Web Server login failed from: 23.225.177.107 User: user
okt-14 19:31:17 Web Server Web Server login failed from: 23.225.177.107 User: admin
okt-14 19:31:17 Web Server Web Server login failed from: 23.225.177.107 User: ktuser
okt-14 19:31:16 Web Server Web Server login failed from: 23.225.177.107 User: admin
okt-14 19:31:13 Web Server Web Server login failed from: 23.225.177.107 User: root
okt-14 19:31:09 Web Server Web Server login failed from: 23.225.177.107 User: user
okt-14 19:31:09 Web Server Web Server login failed from: 23.225.177.107 User: admin
Best regards, Verkenner
Verkenner
Re: Hacker !!!!!!
Postby John » Tue Oct 15, 2019 5:06 am
Verkenner wrote:A hacker with IP 23.225.177.107 is trying to login to my Homeseer. :-(
Send a drone with a bomb to that up address[emoji1]
John
Re: Hacker !!!!!!
Postby PeJeWe » Tue Oct 15, 2019 7:14 pm
when you running it on a PI maybe you can try this.
https://ehoco.nl/beveiliging-van-de-raspberry-pi fail2ban
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
PeJeWe
Re: Hacker !!!!!!
Postby Verkenner » Wed Oct 16, 2019 9:32 pm
Thanks for suggestions gentlemen.
Using Windows10 on a PC.
Cheers, Verkenner
Verkenner
Re: Hacker !!!!!!
Postby Edwin2008 » Sat Oct 19, 2019 7:41 am
Don't open anything to internet. Use vpn to connect. One step extra but saves a ton of trouble.
** edwin **
Edwin2008
Re: Hacker !!!!!!
Postby Verkenner » Mon Oct 21, 2019 8:11 pm
Thanks
I fond: MyHomeseer (sort of VPN)
Cheers, Verkenner
Verkenner
Return to Off Topic
