Remotely turn off/adapt scedule
Is it possible to turn off the automated program (on rooted toon 1)or change program scedule remotely ( using http )
If yes, how to do so?
Thanks,
Thanks,
Re: Remotely turn off/adapt scedule
Remotely you can switch between the four modes (sleep, away, comfort, home).
And on the toon you can disable the program using the disable program button or by entering a manual temperature. But that is also for non-rooted toons
So it's not possible to remotely 'switch' the disable program button? Problem is that when I switch between the modes ( for example to 'afwezig' ) it will be overruled by the enabled program which i would like to disable remotely.
Otherwhise changing the program scedule ( remotely ) could be an option, just like the official toon app.
If you use the Toon Mobile app and you press "weg" for the second time you will see the small lock change from open to close this will disable the program.
You will also see "volgt programma" switch to "continue op weg"
Press it again will go back to the program.
Ron.
Ron.
Yes, with this: http://<ip toon>/happ_thermstat?action=changeSchemeState&state=0knug2 wrote:Is it possible to turn off the automated program (on rooted toon 1)or change program scedule remotely ( using http )
Thanks,
Hi glsf91,
Thanks! This is exactly what im looking for!
Do you know if its possible to change the scedule/program remotely? In a similar way?
I have no idea.knug2 wrote:Hi glsf91,
What do you mean by remotely?knug2 wrote:Hi glsf91,
From outside your house/not connected to wifi?
Connected to wifi should do I think, because there are possibilities to connect from outside to house wifi if needed.RoadXY wrote:What do you mean by remotely?knug2 wrote:Hi glsf91,
I think question is: is there an API on the toon to do this?
- Administrator
No api, yes it can be done via http-calls.glsf91 wrote:Connected to wifi should do I think, because there are possibilities to connect from outside to house wifi if needed.RoadXY wrote:What do you mean by remotely?knug2 wrote:Hi glsf91,
Check the Domoticz manual for the correct http-calls and how to use them: viewtopic.php?f=102&t=12097
