Toon app: Webcam
TerrorSource
Re: Toon app: Webcam
Post by TerrorSource »
Hanzenman wrote:Hi All,
I have a Hikvision camera, is there anyone who has linked this camera to the APP
Best regards, Hans
If you find the correct URL for the camera feed it should work.
bartch wrote:Hi,
i am trying to find the right jpg-stream from a Ski-resort to be displayed on my Toon..is this possible? the only thing i can find is: nl.bergfex.com/oberwiesenthal-fichtelbe ... ams/c7036/ but how do i find the jpg-stream from this?
Ask the one responsible for the feed if they have the correct URL for you. We cannot provide that for you.
newwolf
Post by newwolf »
Hee,
This works for my hikvision camera. (with the newer firmware versions)
http://user:pass@ipaddress/ISAPI/Stream ... 01/picture
Greetz,
Jos
yustmenl
Post by yustmenl »
he guys,
I installed the app and added a cam but now Toon keeps rebooting.
I can ssh to it with a stable connection.
Any ideas on how to solve this?
Thanks!
Edit: looks like tha after 30 minutes of rebooting it came back into the GUI
Rudolf
Post by Rudolf »
My hacked dafang cam doesn't provide a jpeg-url.
I managed to get it working via home assistant API:
https://url.duckdns.org:8123/api/camera ... ken=<token>
Works nicely.
Edit: Nevermind, that token is subject to change, so it stops working after some time.
michel30
Post by michel30 »
When I want to used it, the stream is too high so it does not work on my Toon 1.
It was a good tip to try it with home assistant API....
TerrorSource
Rudolf wrote:My hacked dafang cam doesn't provide a jpeg-url.
Works nicely.
I own a Dafang 1080p myself and hacked it with Xiaomi-Dafang-hacks ( https://github.com/EliasKotlyar/Xiaomi-Dafang-Hacks )
Have you tried: https://dafang/cgi-bin/currentpic.cgi ?
Rudolf
Post by Rudolf »
I thought I'd tried that and failed, but it works now. Thnx.
a3_rotterdam
Post by a3_rotterdam »
Have played today with the webcam app and tried many addresses but till now not very successful.
The IP camera is a MOBOTIX D25. Connected at my own network.
Via Firefox or Chrome the following links are all working fine, sometimes the programs asks for the username/password conformation.
When i try it with Internet Explorer, it will not find the webpage only when i remove the username and password at the address line. It opens then the camera login page.
Have tried:
http://username:password@192.168.178.20 ... stream.jpg
http://username:password@192.168.178.20 ... full&fps=0
http://username:password@192.168.178.20 ... quality=10" encoding="mjpeg"
http://username:password@192.168.178.20 ... urrent.jpg
Is there anyone who have some ideas?
Best regards,
Adri
oepi-loepi
Post by oepi-loepi »
a3_rotterdam wrote:Hello,
Have tried:
Best regards,
Adri
According to ispyconnect you have to try record/current.jpg?sync=-99. For this camera
skadjea
Post by skadjea »
I am not able to get this application to work.
My adres to the webcam (medion ipc-10Ac resulution: 640*320) is http://camadres/snapshot.jpg
The link is working on the pc, but not on the Toon.
What Am I doing wrong.
And is it also possible to make more cams active on the toon?
michel30
Post by michel30 »
I think because the picture is to big in MBs for the Toon.
I had also the same problem.. I shows for a sec and the Toon stopped and reboot because the big size of the picture.
Vriesfde
Post by Vriesfde »
Works nicely.
How did you get around the dafang authentication terrorsource? My dafangs require username/password when accessing the jpg preview page
I tried https://user:pass@dafang-ip/cgi-bin/currentpic.cgi
Works on a pc browser bu on the toon2 I get a blank
Daniel
Post by Daniel »
hanplo wrote:Did someone succeed to view a Dahua cam on the Toon. I need some help.
I know it's a very old question, but for my Dahua this works: http://admin:###password###@192.168.178 ... shot.cgi?1
###password### enter your own password here.
ip- change to your own cam
