This should be a real quality LED light, I will report back when they are burning price 29,95 a piece.
Bulb
3W LED LIGHT BULB
Base
GU10 Twisted Bi-Pin
LED Count
1 x 3W CREE Q5 XR-E
Light Output White
WHITE 240 Lumens
Installation Class
Plug & Play
Beam Angle Bulb
60 degrees
Light Source
Solid State White LED Lamp Dice
Body Materials
Die Cast Aluminium
Life Time
50,000 Hours
Front Protection
Glass Optical Lens
Voltage
110-240V
Wattage
3W
Color Temperature
5,500 7,000 Kelvin
DIMENSIONS
Maximum Overall Length (MOL)
2.28 in ( 68 mm)
Bulb Diameter (DIA)
1.97 in (50 mm)
Base Bi-Pin
0.394 in (10 mm)
Special Features
Light Dimmable Switches Not workable
