Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
jvdheuvel wrote:I try to get the afvalkalender of Uden in the Afvalwijzer app.
As far as I know, Uden is not supported by the afvalverwerkers that are already implemented in the app.
Can this also be implemented in the app?
https://www.uden.nl/inwoners/afval/opha ... PK-65.html
I also downloaded the .ics file, only I cannot find how to upload the file to my Toon.
I noticed there should be a description in the Manuals section, however I cannot find it.
Can someone please help me out with this?
Thanks in advance! :-)
You have to copy your ics file to Toon and rename as /root/waste/waste_calendar.ics (can be done via ssh or tools like WinSCP).
If the folder waste doesn't exist in root you have to create it manually.
Next, in the settings screen of the app you have to select waste provider 25 and that's it
(25 is areaafval.nl, happens to use exactly the same format)
In a future release I will change the app to retrieve the file automatically for you....
Kind regards,
jvdheuvel
Post by jvdheuvel »
Kind regards,
Thanks!
I installed WinSCP and tried get into the Toon, however that doesn't work (or, most likely, I don't use the correct settings).
I bought a rooted Toon and I don't know what the credentials are to log in with SSH
Once I am in, I guess the rest will not be that hard to do... all seems to be quite straightforward....
Are the login credentials normally standard values or something completely else?
Any suggestions what I can try to enter?
Support for our afvalverwerker in the next release would be great.... that way I only need to select the right afvalverwerker, set mij postal code and house number and it will be collected automatically I understand?
Any idea when the new release will be available?
typical login credentials :
user root
password toon
use the scp protocol on port 22 with WinSCP
no timing on the next app release yet...
jvdheuvel
Post by jvdheuvel »
That worked!!
Thanks.... :)
jvdheuvel
Post by jvdheuvel »
Toonz wrote:typical login credentials :
user root
password toon
Thanks! that worked to login.... just have to set the waste provider to 25 when I'm back home and it should work :)
jvdheuvel wrote: Thanks! that worked to login.... just have to set the waste provider to 25 when I'm back home and it should work :)
after copying the ics file, yes....:-)
senaja
Post by senaja »
Christmas trees are picked up in my street on January 6 and 13. The waste calendar does not know this and indicates unknown. How do I fix this?
senaja wrote:Christmas trees are picked up in my street on January 6 and 13. The waste calendar does not know this and indicates unknown. How do I fix this?
The app currently does not have a specific icon and description for christmas tree pickup, that's why you see unknown.
senaja
Post by senaja »
I thought so too, but how do I fix this so that it works properly?
you cannot resolve this yourself without programming. It requires some coding changes in the app and a new icon in the resourcefile.
(it is not high on my to-do list to be honest)
a solution could be to show the christmas tree collection dates as the existing type 'Snoeiafval'. For that I need to know your wasteprovider / city to make the adjustment.
senaja
Post by senaja »
Toonz wrote:a solution could be to show the christmas tree collection dates as the existing type 'Snoeiafval'. For that I need to know your wasteprovider / city to make the adjustment.
The waste processor is HMS and the city is The Hague
And I was thinking they build huge fires in the Hague with the christmas trees...:-)
any way , will have a look later this week
senaja
Post by senaja »
Toonz wrote:And I was thinking they build huge fires in the Hague with the christmas trees...:-)
Good. Thank you. Otherwise we can start huge fires with the Christmas trees in The Hague ... :-)
version 4.50 is available in the ToonStore with a fix for denhaag.nl users: kerstbomen are now shown as 'Snoeiafval' instead of 'onbekend'.
No need to update for other users.
