Good timing, was about to start looking into thisJoskep wrote:And suddenly it works again, i see the icon of plastic, and thats correct for today.
Don'y know how, but it works
Still working fine here. Quick manual:Grutte wrote:Hey,
Is it possible that the Omrin - https://www.omrin.nl/bij-mij-thuis/afva ... alkalender
Is not working anymore? I have put omrin.htm in root/waste/ but cant get it to work.
Hi ,flamingbob wrote:Same problem here. Also see no traffic to Meerlanden (16)
My own calander does work. Changing the provider also shows queries. As soon as I go back to 16 no lookups at all for that provider. Think it happened somewhere between 4.6x
Thanks! Fun how they change providers each year. Will test it at home tonight.Toonz wrote:Hi all,
release 4.63 is available in the ToonStore.
Changelog:
- fix for Meerlanden (16) (they changed backend service provider)
Update the app and go to the settings page, change any item and press 'Opslaan' (this to update the settings file to add a new tag ICSurl)
On your PC goto https://www.meerlanden.nl and login with your zipcode/housenr
when you see your calendar data, press 'Zet in agenda' at the right top of the month calendar
press 'Kopieer' to copy the full url to your calendar ICS file.
On the Toon you need to edit the file /mnt/data/tsc/wastecollection.userSettings.json
Paste the full url between the two "" after the "ICSUrl" tag.
The part should now look like "ICSUrl":"https://wasteprod2api.ximmio.com/api......"
Save the JSON file.
On Toon, goto the Menu, Instellingen, TSC, Restart GUI et voila.
- fix for omrin.nl (21) (paper category was not shown properly due to website change)
No need to update for other users.
Yep, dit was de oplossing! Niet op 3, maar optie 1 kiezen als je Cure als afval-ophaaldienst hebt.marcelr wrote:Had hetzelfde probleem. Cure afvalbeheer heeft het protocol veranderd. Zit nu bij mijnafvalwijzer.nl
Even je afvalverwerker veranderen van 3 in 1 en dan doet-ie het weer.
@Toonz: Ik denk dat je optie 3 gevoegelijk uit de afvalkalender app kunt knikkeren.
Hi,Salih547 wrote:hallo,
Ik krijg niks te zien op de afvalcalender hij laad niks blijt wit, kan mij iemand hepen mijn afval ophaler is optie 25 area-afval.nl.
gegroet,
salih
WAUW can you help me, i want this too, but i do not get any icons when my display is at dim mode.cygnusx wrote:i made a mockup of how i think the afvalwijzer app should look like:
The color of the icon is dependant of the kind of garbage. It only gets this state the day before around 17 o clock. When there is no upcoming garbage, the icon would be gray so it's clear that there is no attention needed. With plastic it is orange etc.
This is how it looks in dim state. When there is no upcoming garbage, then no icon/text. Otherwise a gray icon with the right container.
Multiple containers together? Then a text like "Grijs & Plastic".
What do you guys think?
Works! Thanks again for your hard work!!Toonz wrote:Hi all,
...- fix for Meerlanden (16) (they changed backend service provider)....
