Toon App: Water
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
EchoNL wrote:Received all the parts and installed everything. Really easy install :). I downloaded a bracket from the thingiverse website for the sensus 620 and 3d printed it. Fits perfect!
Keep up the good work!
Very nice installation!
Jasper
Re: Toon App: Water
Post by Jasper »
RoelToonz wrote:Hello
I have flashed the wemos like the subscribtion, i can connect it with the phone set up my wifi but than at point 7 i cant klik on the link so i set a free static ip adres and confirmed it, but i cant find the wemos ip adres in my network so i think i wil not connect to my network. Please help
Did you setup the right address for the router and sub domain?
oepi-loepi
Re: Toon App: Water
After selecting wifi network, fill in your wifi password, static ip, static gateway and subnet. Click save.
Select your wifi network (the one you have selected in the setup) and browse to the static ip adress you have selected (or http://esp-toonwater.local). If you cannot find the adress, power off and power on the Wemos again.
If you are using a old, previous used Wemos, flash the blanco 4MB image first.
EchoNL
Re: Toon App: Water
Post by EchoNL »
Snug fit for the Wemos D1 mini. Project finished. Both things printed from thingiverse.
Toon Water
Toon Water
Toon Water Meter.jpg (168.16 KiB) Viewed 5180 times
oepi-loepi
Re: Toon App: Water
Nice job! I am awaiting for the sensors to arrive and then i can send the first completed devices out.
Arnout2000
Re: Toon App: Water
Post by Arnout2000 »
Finally received my sensor from Ali today. I made a nice holder from plexiglass.
Software and hardware seems to be in order, because if I wave a piece of metal in front of the sensor, the counter in the Wemos web interface goes up.
Problem is that wherever I position the sensor, it does not detect the turning wheel in the watermeter yet.
I probably need to grind the blue tip of the sensor. Haven’t done that yet. How much can I grind off? In the start of this topic 1mm is mentioned. Seems like a lot. Is there risk of grinding too much off?
Jasper
Re: Toon App: Water
Post by Jasper »
Mine works fine without grinding, did you check the detection distance with the piece of metal? And it needs to be aligned off center to work.
Arnout2000
Re: Toon App: Water
My sensor only detects metal when it’s within 4-5mm distance.
Yes, the hole is at the right place, but I also checked different positions on the watermeter manually but nothing is detected.
oepi-loepi
Re: Toon App: Water
Arnout2000 wrote:My sensor only detects metal when it’s within 4-5mm distance.
Did jou drill the hole through the plexiglas so the sensor is in contact with the meter itseld? If so, start to grind a bit of the tip of the sensor bit-by bit. I have a sensor wich has conpletely lost the blue plastic and is still working. I think the plastic is to closes the sensor for water.
Arnout2000
Re: Toon App: Water
I have started grinding. See the photo of the result. When moving the sensor manually over de meter it now detects the coil so that is good News! I can start mounting now.
Yes, the sensor hangs beneath the plexiglass so the tip directly touches the plastic cover of the meter.
oepi-loepi
Re: Toon App: Water
Yes, it is just a plastic cap to close the sensor. Best is to mount it with water flowing.. so open one of the water tap points.
Arnout2000
Re: Toon App: Water
Installation complete. Works like a charm.
I only had to enter the current value of the watermeter in the ESP interface. If I enter the value on the Toon the value becomes weird. Is that a know bug?
Jasper
Re: Toon App: Water
Post by Jasper »
You should enter 231562 and not 231,562 or 231.562
Arnout2000
Re: Toon App: Water
Jasper wrote:You should enter 231562 and not 231,562 or 231.562
Yes that’s what I did. The same applies for the ESP interface. No points or commas.
Jasper
Re: Toon App: Water
Post by Jasper »
You mean first days use? That's normal because it has a previous value which was reported earlier and I cannot tell if that's fixed yet. You should wait for oepie loepie then to confirm.
