Click in the middle of the tile to get to the configuration screen
If you have Hue lights connected to your Toon, the two buttons will be visible, otherwise you will only find one button.
Select your favourite teams from the list. The teams you have selected will be (in short names) added to the text box on the right. When a goal is scored in a match in which your favourite club plays, a notification on Toon will be given. Select the time you like the notification to be presented below. Click "Opslaan" to save the settings.
Select which lamps and Hue scenes should blink when a goal is scored in a match in which your favourite club plays. If you only like to blink the lights and select the scene when your favourite club scores, select "Lampen alleen als favoriet scoort". You can also set the time of the light show.
Now Good Luck, let's hope your favourite team scores!
