Okay, if anyone else has any easier solutions that are limited to Z-wave I'm all ears.
Thanks so far. This requires a bit of learning, so I'll get back to this if I have other questions.
Z-Wave Upgrade for LED-driver with integrated dimmer
- Starting Member
Re: Z-Wave Upgrade for LED-driver with integrated dimmer
I am searching for the same solution and I found a Zwave dimmer with a 0-10V outpunt to control your dimmer driver.
Qubino Flush Dimmer 0-10V ZMNHVD1 Z-Wave Plus
I think I will try this one.
Greetings Rudi
Greetings Rudi
Have you tried the Qubino? I've tried the Qubino and there is some voltage leakage so the lamp does not go out completely
I mailed to Qubino and they say there is a small leakage of 0.4 to 0.6 volts
So my search also goes on.
I do not say I know better, I just think differently.
