Hello Chris,
You can connect an XM10 (http://www.elekhomica.nl/product_info.p ... cts_id=256) to the VP1000.
This enables you to switch X10 modules on and off or dim lighting modules.
Bert
Visonic Powermax RF receiver
Moderators: Rene, Willem4ever
- b_weijenberg
No Firmware upgrade is possible for the XM10. I have the XM10 as well but does not work so good on my Visonic Powermax. Also the possibilities are very limited and indeed its slow.
regards Pieter
regards Pieter
hi chris,
did you found out something about a firmware upgrade for the powermax 433 system ?
The system that I am using is blocked for outgoing calls to a mobile phone, via the firmware.
Sander
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by cdp</i>
<br />Hi
Please can you tell me what you used to connect the VP1000 to the AM10.
Thanks
Chris
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by craig</i>
<br />Hello, Im very interested in this. I have a BT VP1000 which is rebadged Visonic PowerMax+. Currently I have it setup:
PIR->Visonic->AM12->X10->CM12->Homeseer->CM12->X10->Light/X10 device
This works, but the delay is around 2-3 seconds form when PIR detects movement to when light comes on.
With this system, what is delay from activity on PIR to X10 device being switched?
Also, is the firmware upgradable via the USB incase of future updates?
Thanks!
Craig (UK)
Sander
<br />Hi
Thanks
Chris
Thanks!
Craig (UK)
