Plugwise Homeseer Plugin
Rene,
problem solved!!!
install problem, file misplaced in the wrong directory.[:D][:(]
Gr Ruud
problem solved!!!
Gr Ruud
Rene,
Looking good!!
But the on/off button is still present for device how are locked in the Source
Gr Ruud
Looking good!!
Gr Ruud
Look at the fixes description! I removed this feature because I could not get it stable. Only a lock is showed in the device status.
[:I] sorry tipical a case of RTFM
gr Ruud
gr Ruud
- Starting Member
new version works great!!
thanx and regards !
thanx and regards !
Rene,
I have changed something in the plugwise source. A name of a plug.
Now is the old name still in the chart's, and is not active anymore.
But the new name is not presented.
Gr Ruud
Gr Ruud
@Ruud: Strange, when I try this it works as expected. What name is displayed in the Homeseer status screen, the old or new one? Statistics are stored independent on the name of the device. The mac address is the unique identifier.
It's solved, the plug has now after a while the good name.
Gr Ruud
Gr Ruud
It should have the right name just after an update. So dependent on the refresh interval you configured this could be a matter of seconds or minutes.
Hi Rene,
Are you still excepting feature requests or are you waiting for the new plugwise firmware?
I would like to have an option to "see" if a device is in use or standby. This can be done by checking the poser usage and if it's for example higher then 20 watt for one minute my dryer is running. The setting(higer then ....) must be configured per device an can be shown at the device.
Let me hear what you think of this...
I will take a note of all feature requests but do not promise anything. I do not think I will implement this feature. What do you want to do with this feature or is it just to have an overview?
@Rene,
For me all is working fine...only missing thing is the toggle option. I'm still searching for a good solution.
I have another request for another Plugin PMIX35
Hope you will consider writing a good plugin with all the option's
Chak, maybe I will. After the Eaton course I will own one;-) With regards to the toggle option. I do not know what I could do within the plugin to support this option in HSTouch. The HS forum does not respond with any usefull information. I still think it's something within the HSTouch software.
@Rene,
That will be great a good working PMIX35 plugin...
Toggle
I think this is HS common
This option is there for all the devices
When I remap a plugwise device to another device toggle will work.
I don't know any thing about device settings..is there any different when you compare the settings in the DB to another device?
Toggle
I will once again post a question on the HS forum.
