Fully automated rooting script
rotzen
Re: Fully automated rooting script
Post by rotzen »
Ah thats a pitty. So for now the only solution is doing a manual root I guess? Or isn't that also not guaranteed to work?
If you want to debug your script, you can use my Toon btw ;-)
mAiden
Post by mAiden »
Manual rooting will work, fortunately you have a U-Boot where the password is known, and in the manual.
Very important to take 3v3, no 5v. Would advise to take a usb to ttl 3.3v..
Connect jumper wires to the ports in the manual on Toon, and the USB to ttl. And then connect with Putty to Toon via serial port :)
Post by TheHogNL »
mAiden wrote:Manual rooting will work, fortunately you have a U-Boot where the password is known, and in the manual.
No need for this as he already connected his Pi to the Toon. This has all the cables he need to do manual root :-) and have console access.
Post by TheHogNL »
rotzen wrote:Ah thats a pitty. So for now the only solution is doing a manual root I guess? Or isn't that also not guaranteed to work?
Time for a teamviewer somewhere tonight? Just PM me your 06-number so I can whatsapp you.
TerrorSource
Post by TerrorSource »
Tried the --boot-only parameter?
That will bring you in the console acces.
You can try "sudo screen /dev/serial0 115200" if you have screen installed.
Post by TheHogNL »
Terrorsource and me found the cause. /dev/unrandom special file is missing in 5.0.4 u-booted toons.
This is necessary for random password generation and openssl to encrypt the password to write to /etc/passwd.
I have already send MartenJacobs a pull request for a fix. In the meanwhile use my version https://github.com/IgorYbema/ToonRooter
rotzen
Post by rotzen »
Thanks guys! Works like a charm now!
PS> Do you know how to change the root password. I will forget the generated password quite soon I'm afraid ;-)
rotzen wrote:Thanks guys! Works like a charm now!
login to toon and enter: passwd
Post by TheHogNL »
I'm not sure if the 'passwd' command is available from 5.0.4 toons. The earlier busybox removed the passwd command.
If not, you could go to this site: https://unix4lyfe.org/crypt/
Type your password twice, click on randomize DES and then Calculate DES. Paste the generated crypt password into the /etc/passwd file just after the root user name (between the two : ) where the current stored crypted password now is.
Kingnl
Post by Kingnl »
Hii
Just a couple questions. Does this script got the updated busybox and dropbear
I used this script for my toon and notice that FTP not worked. Pushed busybox Into it and bricked it :cry:
And that was with firmware 5.0.4
Okey got a new 1 with firmware 4.22.7
And again used this script and failed to install dropbear
And strange thing about it i use the same script on a r10 and it worked fine
But on a r9 it failes
So Does your script got the updated files thehognl???
TerrorSource
Kingnl wrote:Hii
it does not install busybox. the update-script can do that for you.
dropbear is latest version, the one without dependencies. however there is an issue with Toonrooter on firmware 5.0.4. A Pull request was made by TheHogNL and me to solve it but martenjacobs needs to appy the pull before the changes are made in the original git.
Post by TheHogNL »
Kingnl wrote: And strange thing about it i use the same script on a r10 and it worked fine
What do you mean with r9 and r10? The rooting script is not mine. It is marten jacobs script.
If you PM me, I could teamviewer you into fixing your bricked Toon 1.
Kingnl
Post by Kingnl »
sorry i make an mistake i did meen U-Boot version 2010.09-R8 and the r10 uboot
it seem that the script need a few times befor it install the necessary files
its rooted now
do some1 know how to make a full nand back??
Post by TheHogNL »
Kingnl wrote: sorry i make an mistake i did meen U-Boot version 2010.09-R8 and the r10 uboot
its rooted now
Nand backup is useless as on top of the nand a ubifs is created (on a toon1).
If you want to make a backup of your toon, just tar.gz all your files/dirs to a remote place. If you ever need to recover (u-boot/nfs/tftp method) you could easily restore your tar.gz to the toon1
martenjacobs
Post by martenjacobs »
I rooted a clean Toon with 5.0.4 today and made a few changes accordingly. The PR that TheHogNL made is also merged. I did notice a case where it may fail in some random cases (see the issue I created today). In these cases, rooting again should fix it.
Return to “Toon Rooting”
