all the cable holders are on place now downstairs/upstairs.
I went again to the electronics "store" to pick up a bunch of stuff and the first time we were there we bought a few LED panels.
Working on 30Volts and the light amount is amazing and little to no shade when you hang above it.
Very nice working lamps for in the garage, so he had 1 box left of these and i bought them all , 29 pieces with LED drivers
These will do in my situation, i was planning to buy LED fluorescent tubes, or should i say LED tubes .
But now i will make some nice boxes and in front of these led plates i will place a thin layer of milk white polypropylene plastic that i get at a guy i work for allot so probably cheap/free
This is the light from 1 panel ( they use at 220V 70mA)
Turkish brand as far i could find on the internet
Also got a free pump, this will be placed in the tumble dryer, it has a reservoir that collects all the moist and i did not plan to empty this by hand all the time
Also bought 30 fuses that cover the 0-wire and the phase wire instead of just the phase wire, some for 380V for the garage and the same story 0/phase/phase/phase.
Started to primer the MDF wood for the light cove in the rooms, they do use allot of paint
at first i planned to spray polyester filler on them to get them nice and smooth but since i can't use a paint booth and i do not want to spray it in my garage because of the overspray and mist that will fall down everywere i decided to use a brush and a roller.
Just about 20 more to do and then use filler to make it nice and smooth (epoxy)
Also started to do drill some holes in the wall for the bathroom, going to redo the bathroom later since this only can cost allot and i got to much "projects" at my hands now to start with this as well.
The fuse cabinet i have made a bit more tidy and placed some of the wires in the holder to see what and were because it was pretty messy.
The coming weekend i must drain the warmth pump and solar boiler system so i can relocate the old pipes,
probably the most funny/strange thing is, the previous owner was a entrepeneur, he was a plumber.
But you can't see it on the work he has done, its messy, not documented at all, faulty connections and thats the pipes, if you see the electrics and the things he has build.
Nothing is great to see when you look closer
Also going to put a big part of the wire checklist hopefully into the house, today i received some of my packages and 2700m of wire
This is 3x0.75 mm2 Olflex cable, so if someone is interested in buying some cable ?!, leave me a pm.
Got lucky today, not really HA related but a friend of mine called that they threw away an airtank of a compressor,
since i have a compressor that is only the pump and no resevoir this was a great win for free
Drove to the company and luckily it fitted on my jetski trailer.
My package arrived from the US also, 3 XAP 800 units.
i probably need only one but leave a second one as a spare unit, 1 unit works but the lcd screen is broken and a cooling fan but this is a minor thing.
They do all start , hope i can set it by the menu and doing this by pressing the same buttons on a working unit so i know what and where i am to set the rs232 port etc.
Also a bunch of relays arrived today, bought these last week from marktplaats could not resist.
Only have no holders/feet that comes with the relay but a soldering iron does a great job or buy a separate feet from internet.
If anyone is looking for good relays, same as the cable, leave me a pm.
