Page 3 of 3
PowerMax PRO and NEXT MCW
Posted: Mon Oct 27, 2008 2:26 pm
by Noel
I've asked Chak already so many things that I'm afraid to ask him this :/
But easy come easy go.. So Chak. Any change of you helping me (again) with this setup?
<h6>Anyone interested in time travel meet me here last Thursday!!</h6>
Posted: Mon Oct 27, 2008 2:34 pm
by TANE
I did not see any difference between the plus and the Pro.
What is important before you begin..
the wall mount must be connected..else there will be always a warning.
I hope later this week to receive my interface for the Pro
This will make programming a bit easer.
please send a PM
Posted: Mon Oct 27, 2008 3:11 pm
by Noel
Hang on.. I think that I've got it to work! (fingers crossed)
step one: DO NOT read the manual (I'm serious about this!) It will only put you on the wrong track.
step two: if stuck, ask on this forum.
I'll keep you posted about the 'setup'
Posted: Fri Oct 31, 2008 11:57 am
by Rene
To disable the warning when no phone line is connected you should disable checking the phone line in the communication menu. I use only GSM and needed to disable checking the analog line also. A successful arm of the Visonic will clear the warnings in memory. So untill you successfully arm the Visonic it will warn some alarms (incl. sabotage and errors) are in memory.
Posted: Fri Oct 31, 2008 2:02 pm
by Noel
Hello Rene,
Thank you for this info. Till now I had the Visonic connected to a fake voip port to stop this "warning".
I'll give "your way" a go later today.
