Toon firmware - update script
mAiden
Post by mAiden »
hansgrave wrote:Last week i run the update script on two Toons: once from the second last firmware and once from firmware 4.16.8.
The update from the second last firmware went smooth but by the update from firmware 4.16.8 the proces hang at some point.
Following the instructions from mAiden did the job to get a working Toon back, thanx.
No problem. Fine that my instructions help you :)
Ojp
Post by Ojp »
Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. It worked as a charm!
I am not sure to upgrade to version 5 or higher. Are some interesting features to take the risk?
Adios.
TerrorSource
Post by TerrorSource »
Ojp wrote:Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. I worked as a charm!
Adios.
Why not upgrade to the latest firmware? Booting the Toon/Boxx is a bit faster with 5.x.x firmware.
Adios.
My 2 cents: I read a lot of complaints about delays when taking the Toon out of dim state with firmware 5 on a Toon 1.
I personally prefer 4.x on a Toon 1, feels faster.....booting speed is less relevant for me.
If you have a Toon 2 I would certainly move to version 5 due to better Wifi performance.
Kind regardz,
adval40
Post by adval40 »
yesterday i have updated my firmware with the update script
update failed
i saw into the logfile disk full
which files may i delete ?
Post by TheHogNL »
cleanup /mnt/data/update/*
adval40
Post by adval40 »
this dir is empty
Post by TheHogNL »
Then please check /HCBv2/tmp/opkg-cache
adval40
Post by adval40 »
I has remove the files in this cache dir i have 30mb free
after reboot he did'nt start up
the display hangs in the boot process
no ssh connection possible
adval40
Post by adval40 »
I will try make a new connection via serial
Post by TheHogNL »
Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
What was the previous firmware you where on and to which firmware where you updating to?
whizzz63
Post by whizzz63 »
TheHogNL wrote:Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
I had the same problem. Still trying to repair via a serial connection....
Post by TheHogNL »
From which firmware?
whizzz63
Post by whizzz63 »
5.5.7
Post by TheHogNL »
That is the to firmware I guess :-) I mean what was the firmware before you started the update
Return to “Toon Firmware”
