Toon app: ToonStore
ericT
Re: Toon app: ToonStore
Post by ericT »
I've tried to install ToonStore on my 4.11.6, but get the following error:
eneco-xxx-xxxxxx:~# opkg install toonstore_1.1.1-r0_qb2.ipk
Installing toonstore (1.1.1-r0) to root...
Executing pre-install script for toonstore-1.1.1
grep: /usr/lib/opkg/info/base-qb2-ene.control: No such file or directory
sh: bad number
Hmmm ... no project file found. Shouldn't happen.
The file base-qb2-ene.control doesn't exist, but there is a base-qb2-uni.control...
Eric
This issue has been resolved.
If you have tried to install toonstore-1.1.1 or earlier on FW 4.11.6, please make a copy of /etc/hosts.toonstore_backup before installing a newer version.
Oh, by the way, toonstore-1.1.2 is now available from the toonstore :-)
ToonStore 1.1.3 is available now.
Changelog:
- when there is a ToonStore update available, the button to remove ToonStore was accidentally enabled.
Button will not shop up anymore to prevent unwanted removal of ToonStore.
Kind regardz,
ericT
Post by ericT »
@Marcel Thanks! Install succeeded.
Post by TheHogNL »
Could you please update the easyEnergy app on the store? 1.2.3 is already available in the topic about easyenergy (first post) but the store still provides 1.2.0 which contains a few errors
TheHogNL wrote:Could you please update the easyEnergy app on the store? 1.2.3 is already available in the topic about easyenergy (first post) but the store still provides 1.2.0 which contains a few errors
Sure, can do over the weekend. With future updates drop me a PM when ready......
EasyEnergy version 1.2.3 is available via ToonStore ......
Post by TheHogNL »
Just upgraded Toon to 4.11.6. Toon store isn't showing the firmware in the bottom screen. Because the Toon changed from ene to uni, the firmware check is now pointing to the wrong file.
Has been resolved in toonstore-1.1.2.
Post by TheHogNL »
Hmm I see that in the changelog indeed however, I'm running 1.1.3 and it didn't show the firmware version. Only after I changed the code to look at the uni file instead of ene.
Could be. I changed the installer to reflect the right FW version file (base-qb2-uni<whatever>). Not sure if that also landed in the qml code. Will take a look.
The displayed version number in ToonStore is taken from the file /usr/lib/opkg/info/base-qb2-ene.control.
This should be taken from the file /usr/lib/opkg/info/base-qb2-uni.control for the newest firmwares.
Will change this in next version of ToonStore (next weekend or so)
Never mind, Toonz, it's done already, but thanks anyway. Will test tomorrow. (It's too cold in my attic, right now).
Toonstore updated to 1.1.4, available from the Toonstore. FW version display fixed.
odelay99
Post by odelay99 »
I updated my Toon with the Toon firmware - update script from TheHogNL from 4.4.21 to 4.10.6 and again to the latest 4.13.7 which all went great (thanks for that TheHogNL).
Then I realized that my apps from the toonstore where gone. So I deleted the folders from /qmf/qml/apps including toonstore folder itself. I reinstalled the latest Toonstore but still no apps, I uninstalled with "opkg remove toonstore" and reinstalled again but without any luck.
So now I got the Toonstore installed but when I install an app it shows as not installed after the reboot..
I have attached the log.
Can someone tell me what I'm do wrong?
_opkg.qb2-uni-9.9.99.script.sh.zip
log file
(1.19 KiB) Downloaded 480 times
