Plugwise Homeseer Plugin
Moderators: Rene, RdP
@Wifi: Thanks, but it all comes for free;-) However, I would love Plugwise to send a small donation in the form of an additional set including a circle+ and usb stick so I can start developing a plugin that bypasses the software and communicates directly to the Plugwise hardware.
@All: Any others that experience strange or different behaviour after having upgraded from version 2.0.66 to 2.3.0.x?
@Chak: That problem with the buttons in Rover is a bug in Rover. I already determined what the problem is. I will try to find a fix and report it to it's maintainer.
Thanks..
Toggle problem is the only problem that I can't get it work now.
I did some remapping to a extra device this is working partly.
RdP
Post by RdP »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RdP</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />I did a clean install of WindowsXP, .Net Framework 2.0 and HS 2.3.0.0 and known Homeseer is acting the same as on my development system. This means buttons are hidden when state changes are blocked and you are returned to the status screen when you hit the save button in the device configuration screen. The upgrade from 2.0.66 to 2.3.0.0 seems to mess up things. I will raise this issue at Homeseer. For the time being I do not know how to resolve this problem other than a fresh installation of Homeseer.
I have this problem with all my devices, except the devices created and controlled by the RFXCOM plugin. See all of my lugins in my signature.
I will ask Bert what he did different then others...
By the way, this does not solve the problem with the "Block state changes" button. So this is related to something else.
This is how I make toggle available in HSTouch using BLmapper.
It works fine for now.
[img]uploaded/Chak/2008122012328_Blmapper.gif[/img]
b_weijenberg
Post by b_weijenberg »
Rien,
As it is the same subject, see my answer on the Homeseer forum.
Bert
Rien,
Does the new RFXCom plugin also fix the not disappearing buttons for Plugwise devices?
@Bert: Can I have the link to the beta version of your plugin also? I am wondering if this would solve other strange behaviour I notice.
RdP
Post by RdP »
Unfortunatly not.....
<br />Rien,
So on your fresh installation, the buttons do not disappear when you block state changes for a specific device? Even when hitting F5 to refresh the screen?
Ruud
Post by Ruud »
Rene when i delete a device, in this case a rfxcom device i get:
" In event #32 callback for plug-in Plugwise, object not removed, error: De index valt buiten het bereik. Deze mag niet negatief zijn en moet kleiner zijn dan de grootte van de verzameling.Parameternaam: index Source: Microsoft.VisualBasic"
Gr Ruud
RdP
Post by RdP »
<br />So on your fresh installation, the buttons do not disappear when you block state changes for a specific device? Even when hitting F5 to refresh the screen?
No The problem with the device screen save button is solved and I hoped this was related to the plugwise buttons, but it's not.
At the moment I don't have a test system with the plugwise source software and the plugin available. I hope I can install it today ??
For testing, do I need the plugwise source software and the USB stick installed or can I just install the plugin ??
RdP
Post by RdP »
Tried it on een fresh install and than it's working as expected (no On/Off button)
So now we have to look for the diffences.... Plug-ins is one of them....
RdP
Post by RdP »
I did some more testing on this hidden on/off button issue.
It has definatly something to do with the RFXCOM plug-in. Good News is. Now it's working.... (for me at least)
We did I do:
- Installed the new beta software of RFXCOM (the plugin), You can also disable the plugin to get things working.
- Restart Homeseer
And voila, now it's working
One extra comment if you allready had checked "Block state changes"(before the new RFXCOM plug-in install). you first have to uncheck it, save it, check it again and save it again.
Good luck all,
Ruud
Post by Ruud »
Rene,
What time is given on the status display? My fridge is never ofline but the time today and My Mediacenter is started around 18:00 and now it give's 23:58. strange?
Gr Ruud
