Sorry schelte:
The 1st log is just a summary from the log by doing a "grep "Command: SC"", it was just to demonstrate the last few instances that the command was executed by otmonitor. After that I never san it again while it is configured to do so:
/opt/opentherm//otmonitor --daemon -f /opt/opentherm/otmonitor.conf
and:
cat /opt/opentherm/otmonitor.conf
<SNIP>clock {
year false
date false
auto true
<SNIP>
For the rest: because the timestamp in the log did not reflect the new time, I assumed it was not accepted.
Not sue how much log I need to provide, let's give this a try, otherwise I can send you an entire days worth of logs
22:09:05.410952 Command (via websocket from 192.168.0.179:56223): SC=22:15/5
22:09:05.439462 SC: 22:15/5
22:09:06.215888 R80190000 Read-Data Boiler water temperature: 0.00
22:09:06.314707 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:07.266769 R10010A00 Write-Data Control setpoint: 10.00
22:09:07.306717 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:08.314770 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:08.340864 R801C0000 Read-Data Return water temperature: 0.00
22:09:08.448828 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:09.305490 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:09.414423 R00120000 Read-Data CH water pressure: 0.00
22:09:09.521476 B60120000 Data-Inv CH water pressure: 0.00
22:09:10.314398 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:10.487437 R80190000 Read-Data Boiler water temperature: 0.00
22:09:10.595469 B40192200 Read-Ack Boiler water temperature: 34.00
22:09:11.305850 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:11.561846 R801C0000 Read-Data Return water temperature: 0.00
22:09:11.669838 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:12.313552 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:12.635603 R001B0000 Read-Data Outside temperature: 0.00
22:09:12.742714 B601B0000 Data-Inv Outside temperature: 0.00
22:09:13.305516 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:13.316542 R800500CB Read-Data Application-specific flags: 00000000 203
22:09:13.707528 R900E6400 Write-Data Maximum relative modulation level: 100.00
22:09:13.815546 B500E6400 Write-Ack Maximum relative modulation level: 100.00
22:09:14.313320 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:14.782432 R00000000 Read-Data Status: 00000000 00000000
22:09:14.889339 BC0000000 Read-Ack Status: 00000000 00000000
22:09:15.305230 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:15.854282 R10010A00 Write-Data Control setpoint: 10.00
22:09:15.962263 BD0010A00 Write-Ack Control setpoint: 10.00
22:09:16.313777 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:16.928719 R801C0000 Read-Data Return water temperature: 0.00
22:09:17.036708 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:17.305616 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:18.002458 R00120000 Read-Data CH water pressure: 0.00
22:09:18.111650 B60120000 Data-Inv CH water pressure: 0.00
22:09:18.313641 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:19.075360 R80190000 Read-Data Boiler water temperature: 0.00
22:09:19.183389 B40192200 Read-Ack Boiler water temperature: 34.00
22:09:19.234332 Error 03
22:09:19.269314 Error 03
22:09:19.353314 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:19.478362 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:19.806412 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:20.274213 R001B0000 Read-Data Outside temperature: 0.00
22:09:20.382275 B601B0000 Data-Inv Outside temperature: 0.00
22:09:20.798109 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:20.809585 R800500CB Read-Data Application-specific flags: 00000000 203
22:09:21.019434 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:21.030488 R800500CB Read-Data Application-specific flags: 00000000 203
22:09:21.390204 R801C0000 Read-Data Return water temperature: 0.00
22:09:21.498207 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:21.823168 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:22.455725 R80190000 Read-Data Boiler water temperature: 0.00
22:09:22.563822 B40192200 Read-Ack Boiler water temperature: 34.00
22:09:22.859493 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:23.524483 R80380000 Read-Data DHW setpoint: 0.00
22:09:23.631597 BE0380000 Data-Inv DHW setpoint: 0.00
22:09:23.823595 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:24.586391 R801C0000 Read-Data Return water temperature: 0.00
22:09:24.696382 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:24.858195 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:25.654788 R00000000 Read-Data Status: 00000000 00000000
22:09:25.761807 BC0000000 Read-Ack Status: 00000000 00000000
22:09:25.796783 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:26.723341 R10010A00 Write-Data Control setpoint: 10.00
22:09:26.805354 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:27.797611 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:27.823643 R00110000 Read-Data Relative modulation level: 0.00
22:09:27.931545 BC0110000 Read-Ack Relative modulation level: 0.00
22:09:28.805138 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:28.897854 R801C0000 Read-Data Return water temperature: 0.00
22:09:29.004810 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:29.796736 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:29.971833 R801C0000 Read-Data Return water temperature: 0.00
22:09:30.080853 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:30.832789 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:31.038867 R80190000 Read-Data Boiler water temperature: 0.00
22:09:31.145790 B40192200 Read-Ack Boiler water temperature: 34.00
22:09:31.796735 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:32.101833 R80380000 Read-Data DHW setpoint: 0.00
22:09:32.208857 BE0380000 Data-Inv DHW setpoint: 0.00
22:09:32.805791 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:33.175804 R801C0000 Read-Data Return water temperature: 0.00
22:09:33.283804 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:33.796759 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:34.248787 R00000000 Read-Data Status: 00000000 00000000
22:09:34.355759 BC0000000 Read-Ack Status: 00000000 00000000
22:09:34.805765 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:35.322770 R10010A00 Write-Data Control setpoint: 10.00
22:09:35.429879 BD0010A00 Write-Ack Control setpoint: 10.00
22:09:35.795766 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:36.395755 R00110000 Read-Data Relative modulation level: 0.00
22:09:36.502794 BC0110000 Read-Ack Relative modulation level: 0.00
22:09:36.805801 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:37.469809 R801C0000 Read-Data Return water temperature: 0.00
22:09:37.577837 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:37.796687 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:38.543769 R801C0000 Read-Data Return water temperature: 0.00
22:09:38.650868 BC01C2000 Read-Ack Return water temperature: 32.00
22:09:38.804799 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:39.616734 R80190000 Read-Data Boiler water temperature: 0.00
22:09:39.723747 B40192200 Read-Ack Boiler water temperature: 34.00
22:09:39.795687 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:40.689771 R80380000 Read-Data DHW setpoint: 0.00
22:09:40.804787 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:41.730862 R801C0000 Read-Data Return water temperature: 0.00
22:09:41.808690 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:42.817744 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:42.829699 R00120000 Read-Data CH water pressure: 0.00
22:09:42.935762 B60120000 Data-Inv CH water pressure: 0.00
22:09:43.808763 T800500CB Read-Data Application-specific flags: 00000000 203
22:09:43.900834 R80190000 Read-Data Boiler water temperature: 0.00
22:09:44.008689 B40192200 Read-Ack Boiler water temperature: 34.00
Also just noticed that I get a "Fout 203" on my Celcia-20. But that might not be related.
Last, no rush from my side, all seems to be working fine. And I don't think that the time will make that much of a difference.
EDIT:
Power off of the gateway as well as the boiler cleared the 203 error, and guess what: I now also see the automatic time updates reappearing:
22:32:59.429652 BC000030A Read-Ack Status: 00000011 00001010
22:33:00.000636 Command: SC=22:33/4
22:33:00.028941 SC: 22:33/4
22:33:00.392907 T10015500 Write-Data Control setpoint: 85.00
