Toon apps: feature requests
Ierlandfan
Post by Ierlandfan »
Hi Ierlandfan, I moved your post to a new topic.
best, marcelr
Can we make a vnc client for Toon, so to display whatever we want on Toon? That
would give us even more options... create an app for it and show for example a website that would be too much for Toon itself to handle
TerrorSource
Post by TerrorSource »
Ierlandfan wrote:Little off topic : can we make a vnc client for To on, so to display whatever we want on To on? That
would give us even more options... create an app for it and show for example a website that would be too much for To on itself to handle
What do you mean exactly? Have package for VNC in the ToonStore so you can remote control your Toon via the Toon screen itself?
There's already a manual for in the Rooting Manual.
Re: Toon apps: feature requests
I think he means a VNC viewer so you can show anything on Toon, even windows 10 :).
I guess it can be done but you cannot start it from the regular Toon firmware as it is now. Like the idea though.
hayman
Post by hayman »
hello,,
is there any way to controle Toon useing Amazon Alexa ... ?
TerrorSource
hayman wrote:hello,,
That is already possible with Domoticz/HA-Bridge setup. It is not possible to do that directly.
hayman
Post by hayman »
thanks still not getting it work with domoticz :roll: .....
Vibestar
Post by Vibestar »
Is it possible to makena app to display upcomming events from a calendar (Google calendar)? It could replace our handwritten calendar for the family. That would be great.
Vibestar wrote:Is it possible to makena app to display upcomming events from a calendar (Google calendar)? It could replace our handwritten calendar for the family. That would be great.
Not so easily. What you could do is manually download the calendar in an .ICS format and copy to Toon
Toon cannot access the calendar online (because it is https, needs login etc).
Probably this makes it less usefull.
Kind regardz,
Templar
Re: Toon apps: feature requests: OpenTherm info
Post by Templar »
OpenTherm related info
  • A status display for your DHW boiler, displays boiler manufacturer, type and information like configuration, fault codes etc;
  • A heating/temperature graph;
  • and possibly a message log screen.
Essentially OpenTherm Monitor like features.
Used to be possible, unitl FW 3.5.4, after which someone screwed up the OT messaging of toon. Until someone finds a way to get the bxt messaging in that area going, it's a no-go. Would love to have it as well, though.
Vibestar
Post by Vibestar »
Kind regardz,
Could there be a workaround in the form of a iframe? I read somewhere that the browser abilities of the TOON are not that great. I figured out that a iframe could show the calendar publicly.
It would be a great app :D
Vibestar wrote: Could there be a workaround in the form of a iframe? I read somewhere that the browser abilities of the TOON are not that great. I figured out that a iframe could show the calendar publicly.
Unfortunately Toon doesn't have a browser at all. You can only do simple http requests and then analyze the returned html source code. There is simply not enough memory in the device for a full browser to function.
Regardz,
Templar
Post by Templar »
marcelr wrote:Used to be possible, unitl FW 3.5.4, after which someone screwed up the OT messaging of toon. Until someone finds a way to get the bxt messaging in that area going, it's a no-go. Would love to have it as well, though.
Got FW 4.8.25 installed yesterday. Filled in my boiler info. I think Quby/Eneco is compiling a Data-ID database of boiler models coupled with their corresponding Data-ID's 3 &127. With the next FW release (4.9, in october) they will enable boiler monitoring so I guess OT messaging will be working again by then.
Depends whether they expose the boiler data again via happ_thermstat. If not, it will most likely only work when you have a subscription
Nelus82
Post by Nelus82 »
Hello everybody!
Is it possible to create a app to send HTTP GET request?
I want to activate a Homey flow from Toon
