I have a OKO 5513 and Alevel 0214 attached to my LPG tank for level monitoring, but it's no longer used as I changed supplier. I'm interested in the possibility of receiving data from the Alevel sensor, as it transmits on 433Mhz. In addition, whilst they are sealed units, replacement Alevel 0214 sensors are available cheaply on ebay.
http://www.smartgasmetering.com/doc/Tan ... 160511.pdf
Has anyone come across the protocol that 'Aiut' uses? I must admit, I haven't removed my RFXCom from my Home-Assistant server yet, in order to see what's being picked up, but I thought I would ask here before dismantling things
The protocol seems to be also used for their heat monitoring devices too, and the best I can find is at http://tankmonitoring.com/doc/SHM_OKO55 ... 160322.pdf where it's referred to as 'IMS 433'
Tonight, I'll be moving the RFXTRX to a Windows machine and trying to log all undecoded stuff. The best I have is that it will log every 6 minutes. Maybe I'll set up an SDR too, if I can't catch anything.
Any info greatly appreciated
Kyle
