How to enable Apps/Tiles without a subscription
Forum about Toon related manuals and tutorials. Read-only for most members.
VonFlaffenhausen
Post by VonFlaffenhausen »
I have been browsing this forum for a while now and have learned a lot, thanks!
Have rooted my Toon and been a happy user since. Sadly though, the previous owner decided to stop paying for the Toon subscription and all of a sudden, my Toon is pretty crippled.
Things I really miss :
Energy usage history (graphs)
Smoke Detector status (Have 2 Fibaro smoke detectors I used to be able to see)
Philips Hue (This is a big one for me, I was running HABridge to make my Domoticz devices available on the Toon and I really miss being able to turn on all lights, lower the screens, turn on the TV from my Toon. Even my girlfriend misses it :) )
I have found 2 posts on the forum pertaining to this topic
viewtopic.php?f=87&t=8743&start=195#p78479 (23-01-2016)
and another method where you could edit an XML (can't find the link ).
Both options where posted quite a while ago and I was wondering what the current (best?) method was to enable all the goodies.
Software version: 4.8.25
Firmware Ketelmodule 37
Firmware meteradaprer 0.25/0.13
Thanks in advance for your time and patience!
Re: How to enable Apps/Tiles without a subscription
You can unlock the graph functionality as described here:
viewtopic.php?f=87&t=11234&p=81575&hilit=unlock#p81575
Note: this will not unlock the monthly graphs, for that you will nee d a subscription (that data feed is coming from Eneco)
And edit the file config_happ_scsync.xml (in /qmf/config), and set end date (-1) , productvariant (Toon), and a bunch of flags for your toon.
Afterwards reboot (not only a gui-restart)
killall happ_scsync && killall qt-gui
should do.
reboots are overrated :-)
dennis071nl
Post by dennis071nl »
Note: i had to remove 4 "!" to enable all graphs!
Toonz wrote:You can unlock the graph functionality as described here:
VonFlaffenhausen
Thank you all for the replies.
I have set the enddate to -1 (that already took care of most of it)
Changed Solardisplay and SolarActivated to 1
I am a changed man!
It would be nice to bundle this info and add it to the Wiki
dennis071nl wrote:Note: i had to remove 4 "!" to enable all graphs! ]
Thanks for the feedback, this has changed over time with newer firmware. I have edited the original post.
VonFlaffenhausen wrote: It would be nice to bundle this info and add it to the Wiki
I've never noticed any wiki pages on this forum, can you guide me there?
VonFlaffenhausen
TerrorSource wrote:Possible fix found, at least it helpt 2 people that i know of.
Made a entry in a new Wiki-topic.
viewtopic.php?f=87&t=11777&p=83254#p83254
I saw it referred to as a wiki.
adjego
Re: Rooting Toon (or boxx)
Post by adjego »
So today i updated Toon using the method provided to keep SSH access which worked great. But there is one issue i can't seam to fix.
Before the update i had some adapted app tiles which were fetching custom data for me. But now even when the whole "solar" is enabled, i still am not able to choose any of these tiles. It only shows the selection of the normal gas and electric ones. What am i missing?
My config_happ_scsync.xml contains this:
<device>
     <package>happ_scsync</package>
     <uuid>neco-001-079592:happ_scsync_612487339CB</uuid>
     <type>agreementDetail</type>
     <internalAddress>agreementDetail</internalAddress>
     <visibility>0</visibility>
     <StartDate>1418083200</StartDate><EndDate>1482364800</EndDate>
     <Status>IN_SUPPLY</Status>
     <ProductVariant>Toon</ProductVariant>
     <activated>1</activated>
     <wizardDone>1</wizardDone>
     <SoftwareUpdates>0</SoftwareUpdates>
     <BoilerManagement activated="0">0</BoilerManagement>
     <ElectricityDisplay>1</ElectricityDisplay>
     <GasDisplay>1</GasDisplay>
     <HeatDisplay>0</HeatDisplay>
     <SolarDisplay>1</SolarDisplay>
     <SolarActivated>1</SolarActivated>
     <OtherProviderElec>1</OtherProviderElec>
     <OtherProviderGas>1</OtherProviderGas>
     <SME>0</SME>
     <HeatWinner>1</HeatWinner>
     <ContentApps>1</ContentApps>
     <TelmiEnabled>1</TelmiEnabled>
     <mobileAccess>0</mobileAccess>
     <supportEnabled>0</supportEnabled>
     <supportEnabledStart>0</supportEnabledStart>
     <researchEnabled>0</researchEnabled>
     <doSolarWhatsnew>1</doSolarWhatsnew>
     <latestWhatsnewVersion>qt-gui - 1.6144-ene-develop</latestWhatsnewVersion>
     <statusUsageFirstUse>0</statusUsageFirstUse>
     <scStatusFlags>0</scStatusFlags>
     <commissionState>0</commissionState></device>
    <device>
Moved to a better fitting topic.
Try and set your end date to -1.
adjego
Post by adjego »
Thanks for the tip, changed it but need to wait untill i get home to see if it helped. One other question. How can i get rid of the annoying message at the top of the screen that i have no connection? I't because the VPN is turned off but that message is quite annoying.
There's a thread on the notifications bar in this forum.
FunFair
Post by FunFair »
ok... what am I doing wrong? I've updated to 4.10 and lost some functionality. I can see all tile options, but I can't seem to click on any of the gas or electricity tiles for more detail.
I've changed config_happ_scsync.xml to the following below
<device>
<uuid>neco-001-047334:happ_scsync_61123C6EA94</uuid>
<StartDate>1392940800</StartDate>
<EndDate>-1</EndDate>
<SoftwareUpdates>1</SoftwareUpdates>
<SolarDisplay>0</SolarDisplay>
<SolarActivated>0</SolarActivated>
<OtherProviderElec>0</OtherProviderElec>
<OtherProviderGas>0</OtherProviderGas>
<SME>0</SME><HeatWinner>0</HeatWinner>
<TelmiEnabled>0</TelmiEnabled>
<doSolarWhatsnew>0</doSolarWhatsnew>
<latestWhatsnewVersion>qt-gui - 1.5077-release-3.2.9-with-dateselectorco</latestWhatsnewVersion>
<scStatusFlags>4</scStatusFlags>
</device>
and I've changed this 4 times in GraphApp.qml
if (!globals.features["standalone"]) {
to
if (globals.features["standalone"]) {
Am I missing something?
-update-
I changed the !'s back and now it works!
Seems something to do with the toon not registered as standalone unit anymore.
Arcidodo
Post by Arcidodo »
I had an simular issue.. i updated my Test Toon and had about 6 apps. and the file config_happ_scsync.xml was correct...
i found the file TenantSettings.json on my working toon and is was not available on my test toon.. i added the file and the apps are back..
cat /qmf/qml/config/TenantSettings.json
        "appWeather": "weather",
        "appGraphTileLowestUsage": true,
        "i18nLocales": [
                "nl_NL"
	"appWhatIsNewAutostart": false,
        "enabled2ndMeterModule": false,
        "enabledManualConfiguration": false,
        "enabledHeaterFuelConfiguration": false,
        "enabledGasMeterConfiguration": false,
        "appEMetersSettingsAdvancedDisabled" : false,
        "appSystemSettingsFactoryResetDisabled" : false,
        "appControlPanelSmartplugHardRemoveDisabled" : false,
        "appControlPanelPinProtectRemoveBridge" : false,
        "appControlPanelLampRenameDisabled" : false,
        "appControlPanelPlugRenameDisabled" : false,
        "appControlPanelHueSceneSaveDisabled" : false,
        "appInternetSettingsPinProtectWifiNetworkChange" : false,
        "featSMEEnabled" : true,
        "featShowEnergyMeterImages" : true,
        "featHolidayOffPeakEnabled" : true,
        "featSmokeDetectorSensitivityEnabled": true,
        "featAlarmControlEnabled" : true,
        "homeMenuIconTiles": true,
        "appSolarEnabled" : true,
        "appTrafficEnabled" : false,
        "appBenchmarkEnabled" : true,
        "appWhatIsNewEnabled" : false,
        "appWhatIsToonEnabled" : true,
        "appStatusUsageEnabled" : true,
        "appSmokeDetectorEnabled" : true,
        "appHeatRecoveryEnabled" : true,
        "appBoilerMonitorEnabled" : true,
        "appCustomerServiceEnabled" : true,
        "appInboxEnabled" : true,
        "installationWizardApps" : [
                "internet|true",
                "activation|true",
                "update|false",
                "emeters|false",
                "boiler|false"
Return to “Manuals/tutorials”
