I "confiscated" the space under the stairs to become the "Home Control Datacenter" and started building. It took some time before I had everything up and running, but around february this year i had a working 1-Wire counter that monitored the gas usage and i had written a piece of software to put all counter data in a SQL database.
Since then i almost haven't had any time to spend on HA; however, since a couple of days i have resumed the reliability testing on the counter and still have to solve some issues.
Here some pictures from my work in progress:
Screendump of my HCS-PC:
Showing the SQL database, a Velleman PCS-10 datalogger for reviewing signal
quality, and my Home Control Software (i wouldn't call it a system yet...)
Picture of the gas meter:
With a CNY70 in front of the last digit and a large aluminum case for
the electronics on top of it (yes, it's big for a 1-Wire Counter, but i'm anticipating future expansion of 1-Wire stuff here...)
Picture of my "Home Control Datacenter"
Once the reliability issues i'm facing right now are solved, i'll move on and start monitoring the electricity usage by means of a KWh-meter with S0-interface and monitoring water usage with 2 water meters from Alaxa. All required hardware has already been purchased, now it's just a matter of (a lot of) time to get the job done...
