Toon only showing current usage, no daily, weekly, monthly?
jozg
Post by jozg »
Hello all,
I rooted a toon from a friend a couple of months ago.
From te beginning this toon is not showing daily, weekly and monthly usage.
It is only showing current usage.
Is there something wrong in a config maybe? My own 2 piece of toons doesn't ever had this issue.
Thanks for helping!.
TerrorSource
Re: Toon only showing current usage, no daily, weekly, monthly?
Post by TerrorSource »
My guess is that the Toon config settings are not correct.
See: viewtopic.php?f=100&t=11235#p83254
Set these settings:
<EndDate>-1</EndDate>
set to: -1
<ProductVariant>Toon</ProductVariant>
"Standalone" or "Toon", value "Standalone" will disable the "full menu" options. Value "Toon" + valid EndDate activates "full menu" options.
set to: Toon
<activated>1</activated>
"0" or "1", activation of the Toon
set to: 1
<wizardDone>1</wizardDone>
"0" or "1", value "0" will activate the "initial setup" screens after a reboot. recommended to use when Toon is sold.
set to: 1
<SortwareUpdates>1</SortwareUpdates>
"0" or "1", value "1" will activate firmware updates.
set to: 1
<ElectricityDisplay>1</ElectricityDisplay>
"0" or "1", displays electricity usage, graphs and options.
set to: 1
<GasDisplay>1</GasDisplay>
"0" or "1", displays gas usage, graphs and options.
set to: 1
jozg
Post by jozg »
Hello Terrorsource,
Thanks for your reply.
I checked the config_happ_scsync.xml file and all the settings are the same you suggesged.
Maybe something else?.
TerrorSource
jozg wrote:Hello Terrorsource,
Normally you need to have an active subscription. Setting the EndDate to -1 will set it to infinity.
Also ProductVariant needs to be set to "Toon". if it's Standalone not all functions will work (like usage history)
ElectricityDisplay and GasDisplay is needed to set the Tile's and the possibility to click on the Tiles to see the usage history.
Did you disable VPN and did a reboot?
jozg
Post by jozg »
Hello Terrorsource,
The VPN is closed and the tiles are showing up.
The enddate is set to -1 and the product variant is also toon. And gas and elec display is set to 1.
I could update using the update script? maybe it helps.
It's case sensitive, so "Toon", not "toon".
jozg
Post by jozg »
Hello all,
Thanks for helping.
This is a copy/paste from a part of the config_happ_scsync.xml file:
     <visibility>0</visibility><StartDate>1428883200</StartDate><EndDate>-1</EndDate><ProductVariant>Toon</ProductVariant><activated>1</activated><wizardDone>1</wizardDone><SoftwareUpdates>1</SoftwareUpdates><ElectricityDisplay>1</ElectricityDisplay><GasDisplay>1</GasDisplay><HeatDisplay>0</HeatDisplay><SolarDisplay>1</SolarDisplay><SolarActivated>1</SolarActivated><OtherProviderElec>1</OtherProviderElec><OtherProviderGas>1</OtherProviderGas><SME>0</SME><HeatWinner>0</HeatWinner><ContentApps>0</ContentApps><TelmiEnabled>0</TelmiEnabled><mobileAccess>1</mobileAccess><supportEnabled>0</supportEnabled><supportEnabledStart>0</supportEnabledStart><researchEnabled>0</researchEnabled><doSolarWhatsnew>0</doSolarWhatsnew><latestWhatsnewVersion>qt-gui - 1.7978-ene-hotfix-4.9</latestWhatsnewVersion><statusUsageFirstUse>0</statusUsageFirstUse><scStatusFlags>0</scStatusFlags><commissionState>0</commissionState></device>
I think it should be fine?.
TerrorSource
Is there a physical ZonOpTon or other Kwh-meter present? if not, set SolarActivated and SolarDisplay to 0.
Have you tried changing OtherProviderGas and OtherProviderElec to 0 as well ? Dont have a Toon preset but i thought that those value's are 0 in my Toon.
jozg
Post by jozg »
Hello Terrorsource,
I'll try, and let you know.
Thanks.
Also, try this : <EndDate>1627485995</EndDate>
I found that the enddate of -1 not always give the desired results
jozg
Post by jozg »
Thanks for the tips.
It looks like it's working, but today usage, is shown as shaded.
I'll check tomorrow when this day is over.
Rudolf
Post by Rudolf »
The shaded bar for this day/week/month is normal behaviour. It's Toon's way of saying this value is subject to change.
Previous days/weeks/months will be shown as a solid blue bar.
jozg
Post by jozg »
Hello All,
It helped, thanks!.
Another question, i have this one "to test" so i connected it to my P1 port.
Now it thinks it used monday (when i connected it) almost 6000KwH, because i have an other P1 port then my friend.
Is there a way to delete or change the incorrect usage (because of the other meter) before i give it back.
He lives 200km's from my home.
Or is the only way to do factory reset, and connect the meter adapter again in the house from my friend?
What i remembered from a factory reset that some of the files are "empty" again,wich files are overwritten? so i can make backups from it.
Thanks.
regards,
TerrorSource
jozg wrote:Hello All,
It helped, thanks!.
Thanks.
regards,
it should be possible to remove the rrd database with the p1 values but the easiest is just to reset to factory reset.
richardklasens
Post by richardklasens »
Hi Guys.
Small question,
I’ve recently stopped my subscription with Eneco and since the official end date, My tiles for power/gas usage daily/monthly/yearly are gone. I’ve checked the file config_happ_scsync.xml but there are no lines with activation/product/electric/gas etc. Can i just add them as shown in the copied code as shown above?
Thnx!
