Updating old Toon
Updating old Toon
Someone gave me an old Toon to use because they know I like to root them etc..
Rooting with the script was no problem, however, when trying to use the update script I keep getting following error messages:
Even the first time trying to upgrade I already received the message that it already tried downloading a version befor (But as far as I know the person I got the Toon from never had it connected to wifi).
Would love to hear if you have any ideas
Your Toon already tried downloading version Collected errors: before. Need to force this version!
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
cat: can't open '/HCBv2/env': No such file or directory
Progress: 51% ..
Prepare failed. Please check the logs at /HCBv2/tmp/opkg-cache/upgrade-qb2.sh.log
In log:
>> 2019-05-17 13:40:28 +0000 (pid 7996) upgrade-qb2.sh qb2 Collected errors: iptables.backup iptables.save passwd.backup update-rooted.sh opkg_conf_load:
>> 2019-05-17 13:40:28 +0000 (pid 7996) iptables.backup
>> Unknown ACTION arg! Aborting.
>> logKeyValText: key(upgrade-exit-status), value(iptables.backup-error-unknown-action) and text({"fromVersion":"","toVersion":"errors:"})
>> 2019-05-17 13:40:29 +0000 (pid 7996) iptables.backup-error-unknown-action 'Unknown ACTION arg! Aborting.'
yes
Progress: 51% ..
In log:
Re: Updating old Toon
Can you do a and post the output?
Somehow the script is mixing up some internal variables...
opkg list base-qb2*
This is the output from opkg list base-qb2*
base-qb2-ene - 4.7.23-1147-0 - BASEPKG base-qb2-ene r1147 -- contains base files needed for this project + dependencies
base-qb2-ene - 2.8.16-753-0
base-qb2-ene - 2.7.22-730-0
Ok that means that the script wants to update to 4.7.23 first (because your Toon is already halfway towards updating to this version). But somehow it is mixing up and messing with the variables.
It shows "version: Collected erros:" instead of "version 4.7.23".
Try to run
Try to run
update-rooted.sh -v 4.72.3
Thanks for your ideas,
However, they did not work. I tried forcing the upgrade, but after the download of version 4.7.23 it was waiting a really long time on status "Waiting to finish, this can take a minute or 2"
Afterwards I got the same error.
Forcing version: 4.7.23
yes
Killing process... took to long!s takes a minute or two .
yes
Now check that log file: /HCBv2/tmp/opkg-cache/upgrade-qb2.sh.log
I also have an problem whit old Toon, wont boot after update only 2 white dots light up on the red TOON screen.
try the update script an -f but no succes.
Your Toon already tried downloading version 4.22.7 before. Need to force this version!
Could not enable VPN in a normal reasonable time!
DEBUG information:
192.168.178.0/24 dev eth0 scope link src 192.168.178.130
172.25.112.0/20 dev tap0 scope link src 172.25.123.235
172.25.112.0/20 via 172.25.112.1 dev tap0 metric 1024
default via 192.168.178.1 dev eth0 metric 10
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost eneco-001-375169
172.27.32.1 feed.hae.int feed
END DEBUG information
Quitting the upgrade. It was a nice try tho…
eneco-001-375169:~# opkg list base-qb2*
base-qb2-uni - 4.22.7-1273-0 - BASEPKG base-qb2-uni r1273 -- contains base files needed for this project + dependencies
is there a list to check al the folders/files?
DEBUG information:
You toon tried to install 4.22.7 before (on what version is it now?) and failed. Now it is stuck in updating. Somehow the /etc/hosts file isn't updated after the vpn has started. Some old Toon's do have this problem.Daniel wrote:I also have an problem whit old Toon, wont boot after update only 2 white dots light up on the red TOON screen.
I have just uploaded version 3.90 of the script which works better in this case. Wanted to change this a long time but now I finally did this. So please try again (with a updated version of the script).
thanks : i try the new script. 3.90
yes
Progress: 0% .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
eneco-001-375169:~# /mnt/data/update/upgrade-qb2.sh.log
-sh: /mnt/data/update/upgrade-qb2.sh.log: Permission denied
Whit WinSCP :
>> 2019-05-30 07:49:53 +0000 (pid 1478) upgrade-qb2.sh qb2 4.22.7 prepare
>> logKeyValText: key(upgrade-exit-status), value(-error-unknown-action) and text({"fromVersion":"","toVersion":"prepare"})
>> 2019-05-30 07:49:54 +0000 (pid 1478) -error-unknown-action 'Unknown ACTION arg! Aborting.'
yes
Progress: 0% .
Whit WinSCP :
What is the output of
Or try version 3.91 which contains some debugging about what I suspect what is gonig wrong.
opkg list-installed base-*
eneco-001-375169:~# sh /root/update-rooted.sh
Welcome to the rooted Toon upgrade script. This script will try to upgrade your Toon using your original connection with Eneco. It will start the VPN if necessa ry.
Version: 3.91 - TheHogNL & TerrorSource & yjb - 30-5-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Could not determine you current running flavour.
DEBUG:
eneco-001-375169:~# opkg list-installed base-*
base-files - 3.0.14-r100
base-passwd - 3.5.20-r1
DEBUG:
Ok the Toon is missing a crucial file. Unknown which version it is running now.
Try new version 3.92 which takes the flavour from the ready to install file (base-qb2-uni 4.22.7).
I made a small donation, treat yourself a beer!
>> 2019-05-30 10:26:32 +0000 (pid 3753) upgrade-qb2.sh qb2 uni 4.22.7 prepare
>> 2019-05-30 10:26:32 +0000 (pid 3753) prepare
>> 2019-05-30 10:26:32 +0000 (pid 3753) preparing
>> logKeyValText: key(upgrade-prep-info), value(upgrade-prep-start) and text(afv=qb2/uni/4.22.7)
>> Hotfix for writing System Time to RTC
Hardware Clock before: Thu May 30 10:26:27 2019 0.000000 seconds
Hardware Clock after : Thu May 30 10:26:32 2019 0.000000 seconds
>> configured opkg feeds:
src/gz base http://feed.hae.orig/feeds/qb2/uni/4.22.7
src/gz oebase http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... 17-splash2
src/gz oekern http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6
>> opkg_dl.update: opkg --cache /mnt/data/update --download-only update # try 1/5
>> opkg_dl.update.supervisor: monitoring /mnt/data/update for threshold 5000
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.gz.
Updated list of available packages in /var/lib/opkg/base.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.sig.
Signature check passed.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ackages.gz.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ackages.gz.
Updated list of available packages in /var/lib/opkg/oebase.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ckages.sig.
Updated list of available packages in /var/lib/opkg/oekern.
> opkg_dl.update: Exit code: 0
>> Unknown old flavor! Aborting.
>> logKeyValText: key(upgrade-exit-status), value(prepare-error-unknown-old-flavor) and text({"fromVersion":"","toVersion":"4.22.7"})
>> 2019-05-30 10:26:37 +0000 (pid 3753) prepare-error-unknown-old-flavor 'Unknown old flavor ! Aborting.'
> opkg_dl.update.supervisor: Exit
Thanks for the donation
Ok now the real update script from Eneco has problems with finding the old flavour also
Please run this to install the missing file
and after that try another update
opkg install http://qutility.nl/base-qb2-uni_4.22.7-1273-0_qb2.ipk
Yes that`s the trick!
Thanks for help!
Thanks for help!
