After rooting a few Toons I thought the cabling could be more easy. So I bought some stuff and made a cable for an easy connection between Toon and a Raspberry pi (tested pi 3 and 3+). Here I will tell you what you need and how to make the cable for the automated rooting script.
I made 2 extra cables and I would like to give them for free to people who made the rooting scripts or made some apps. Send me a message with proof of your work and I will send you a cable for free (I only have 2 cables yet).
Warning: Only use this information for yourself. It is not meant to help you with selling rooted toons on market places or make any profit.
Hardware:
Dupont cable 20 cm female/female from aliexpress, banggood or other chinese shops.
https://www.banggood.com/40pcs-20cm-Fem ... rehouse=UK
Dupont block 2x7 pins to connect Toon:
https://nl.aliexpress.com/item/32825625 ... st=ae803_5
Dupont block 2x20 pins to connect Raspberry pi:
https://nl.aliexpress.com/item/32828726 ... st=ae803_5
Dutch shop dupont stekkers: https://www.vanallesenmeer.nl
Making the Cable:
Take 11 wires and release them from there single connector by flipping the plastic with a sharp knive.
Hold the 11 wires together.
Make a white mark (Tipp-ex) on pin 1 of the 2x7 and 2x20 pin connectors.
Use the pin layout of the automated root script:
Put the 11 wires in the 2x7 connector: Don’t use pin 1 , 9 and 12
Pin layout:
Now put the wires in the 2x 40 pin connector: (Don’t forget to mark pin one).
Pin layout:
Enjoy your new cable:
