Remeha iSense and C-mix
thomas_n
Post by thomas_n »
Hi everyone,
I have a Remeha boiler which also has a C-mix unit which enables it to control 2 zones. This module is controlled by an iSense thermostat.
Now the special thing about this setup is that the iSense thermostat controls both zones over a single OpenTherm line.
Is this supported in any way by the OpenTherm gateway? I have the module set up, but it is not connected to my computer (yet).
Thomas
Re: Remeha iSense and C-mix
I assume you are referring to the use of the message IDs for a second CH circuit (ID8, 23, 31, 37 and some bits in ID0). The OTGW has no commands to manipulate these. But it will report them and pass them on.
