something strange in config_happ_scsync
I just did an update in TSC menu, this all went well without a problem.
I immediately disabled a few options in Toon sebscription features i only left zon op toon on.
After restart, the zon op toon disappeared from the home screen, but is stil on in sebscription feature.
when i look in config_happ_scsync I miss the line of options or has completely changed?!
<Config packageRevision="444">
<sysConfig>
<locale>nl_NL</locale>
<timezone>Europe/Amsterdam</timezone>
<currency>EUR</currency></sysConfig>
<device>
<serial_number>16-10-023-404</serial_number>
<device_type>MeterAdapter</device_type>
<device_model>6599-1500-0201</device_model>
<hardware_version>6599-1500-0201</hardware_version>
<manufacturer>Quby</manufacturer>
<devicePackage>hdrv_p1</devicePackage>
<devUuid>95535944-4a92-46e8-b2ba-942341fcf7e3</devUuid>
<package>happ_scsync</package>
<uuid>2427408b-bdff-4bfd-95dc-2266dc80cea1</uuid>
<type>deviceInfo</type>
<name>deviceInfo</name>
<internalAddress>16-10-023-404</internalAddress>
<visibility>0</visibility></device>
<device>
<serial_number>15-13-011-347</serial_number>
<device_type>Display</device_type>
<device_model>6500-1400-2001</device_model>
<hardware_version>6500-1400-2001</hardware_version>
<manufacturer>Prodrive</manufacturer>
<devicePackage>hcb_config</devicePackage>
<uuid>b5571390-222d-4e39-9db7-9a2738732fa2</uuid>
<internalAddress>hcb_config</internalAddress>
<visibility>1</visibility></device>
<device>
<serial_number>16-23-004-353</serial_number>
<device_type>BoilerAdapter</device_type>
<device_model>6599-1500-0300</device_model>
<hardware_version>6599-1500-0300</hardware_version>
<devicePackage>happ_thermstat</devicePackage>
<uuid>9e475557-3751-486f-9d7e-e3f112ff3792</uuid>
<internalAddress>16-23-004-353</internalAddress>
<visibility>1</visibility></device><device>
<uuid>81b944d6-e434-414b-b93a-f89013240d12</uuid>
<type>agreementDetail</type>
<internalAddress>agreementDetail</internalAddress>
<StartDate>0</StartDate>
<EndDate>-1</EndDate>
<ProductVariant>Toon</ProductVariant>
<activated>1</activated>
<wizardDone>1</wizardDone>
<ElectricityDisplay>1</ElectricityDisplay>
<GasDisplay>1</GasDisplay>
<HeatDisplay>0</HeatDisplay>
<SolarDisplay>1</SolarDisplay>
<SolarActivated>1</SolarActivated>
<OtherProviderElec>0</OtherProviderElec>
<OtherProviderGas>0</OtherProviderGas>
<SME>0</SME>
<HeatWinner>0</HeatWinner>
<mobileAccess>1</mobileAccess>
<supportEnabled>0</supportEnabled>
<supportEnabledStart>0</supportEnabledStart>
<researchEnabled>0</researchEnabled>
<doSolarWhatsnew>0</doSolarWhatsnew>
<latestWhatsnewVersion>qt-gui - 1.9691-fix-5-13-hotfixes</latestWhatsnewVersion>
<statusUsageFirstUse>0</statusUsageFirstUse>
<scStatusFlags>0</scStatusFlags>
<commissionState>0</commissionState>
<features></features>
<featureInputs></featureInputs></device></Config>
<sysConfig>
<device>
<device>
<device>
<SME>0</SME>
Re: something strange in config_happ_scsync
It just got rewritten in a proper xml style (extra carriage returns). And should not matter how your toon reads this. Just tested it on my toon and no problem to keep solar activated.
Hmm strange.
Normally after change something the Toon wil reboot. But now nothing happens.
Have you any suggestions?
If you think it is the scsync file what is wrong just remove it (after making a backup) and reboot. Toon will set a new scsync file.
I renamed the file and restarted the Toon.
The scsync file looks like it used to be, reactivate zon op toon but I can't select any of it ore see it.
Ok try thisDaniel wrote:I renamed the file and restarted the Toon.
sed -i 's#startqt >/dev/null#startqt >/var/log/qt#' /etc/inittab ; init q ; killall -9 qt-gui
After it start do a
grep -i solar /var/log/qt
Don't forget to stop the logging when you are done debugging or else your toon will fill up the disks with logging within a few days:
sed -i 's#startqt >/var/log/qt#startqt >/dev/null#' /etc/inittab ; init q ; killall -9 qt-gui
thanks for help!
is this what you mean?
Toon:~# grep -i solar /var/log/qt
qml: Trying to load unregistered tile qrc:/apps/graph/SolarThisMomentTile.qml fr om config
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/SolarThisMom entTile.qml timestamp=1570898923
qml: Trying to load unregistered tile qrc:/apps/graph/SolarGenerationTodayTile.q ml from config
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/SolarGenerat ionTodayTile.qml timestamp=1570898923
qml: Trying to load unregistered tile qrc:/apps/graph/GraphSolarDayTile.qml from config
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphSolarDa yTile.qml timestamp=1570898923
qml: Trying to load unregistered tile qrc:/apps/graph/GraphSolarHourTile.qml fro m config
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphSolarHo urTile.qml timestamp=1570898923
qml: Trying to load unregistered tile qrc:/apps/graph/GraphEuroSolarDayTile.qml from config
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphEuroSol arDayTile.qml timestamp=1570898923
Toon:~# Toon:~# sed -i 's#startqt >/dev/null#startqt >/var/log/qt#' /etc/inittab ; init
-sh: Toon:~#: not found
Toon:~#
Usage: init 0123456SsQqAaBbCcUu
Toon:~#
No but you didn't copy paste it correctly also I think.
What did you do here?
TheHogNL wrote:No but you didn't copy paste it correctly also I think.
Pressed the wrong mouse button
I will try again
- login as: root
root@192.168.178.126's password:
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/SolarThisMom entTile.qml timestamp=1570905048
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/SolarGenerat ionTodayTile.qml timestamp=1570905048
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphSolarDa yTile.qml timestamp=1570905048
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphSolarHo urTile.qml timestamp=1570905048
[hcom]Sending HBXT_ACTION_INVOKE from Toon:qt-gui to Toon:happ_kpi/Logger: n=Log Message appKey=missingTileRegistrationInfo appValue=qrc:/apps/graph/GraphEuroSol arDayTile.qml timestamp=1570905048
Toon:~#
Ok so yes the solar app isn't started. The toon was rebooted after enabling solar in the scsync file? And what version firmware are you on?
Normally if both the solar options in the scsync file are enabled the solar app should load.
Yes the Toon is reboot after enabling solar in the scsync (<SolarDisplay>1</SolarDisplay><SolarActivated>1</SolarActivated>)
update to 5.13.12 all good.
After the toon has restarted (the solar panels still worked) i put off some toon features apps in the tsc menu because the toon become slow.
Only left zon op toon on.
Then the toon restarted and the solar panel screen was gone.
owh wait, can you check your /qmf/qml/config/TenantSettings.json file?
And if that is empty (what i'm thinking) put this into it:
This means that your file got empty while saving these features.
"appWeather": "",
"appGraphTileLowestUsage": true,
"i18nLocales": [
"nl_NL"
"appWhatIsNewAutostart": false,
"enabledHeatingSourceConfiguration": false,
"enabledGasMeterConfiguration": false,
"appEMetersSettingsAdvancedDisabled": false,
"appSystemSettingsFactoryResetDisabled": false,
"appControlPanelSmartplugHardRemoveDisabled": false,
"appControlPanelPinProtectRemoveBridge": false,
"appControlPanelLampRenameDisabled": false,
"appControlPanelPlugRenameDisabled": false,
"appControlPanelHueSceneSaveDisabled": false,
"featSMEEnabled": true,
"featShowEnergyMeterImages": true,
"featHolidayOffPeakEnabled": true,
"featSmokeDetectorSensitivityEnabled": true,
"featAlarmControlEnabled": true,
"featHumidityEnabled": true,
"featContactSettingsTabEnabled": true,
"appSolarEnabled": true,
"appBenchmarkEnabled": false,
"appWhatIsNewEnabled": false,
"appWhatIsToonEnabled": false,
"appStatusUsageEnabled": false,
"appSmokeDetectorEnabled": false,
"appHeatRecoveryEnabled": true,
"appBoilerMonitorEnabled": false,
"appCustomerServiceEnabled": false,
"appInboxEnabled": true,
"appUpsellEnabled": true,
"installationWizardApps": [
"internet|true",
"activation|true",
"update|false",
"emeters|false",
"boiler|false"
You were right the file was empty.
It works again!
Thanks for helping.
