Toon keeps hopping back to 20 degrees
If you don't know where to post, post here.
RobbieT
Post by RobbieT »
I've rooted my Toon (1) a while ago and everything works fine. I can control the Toon from Domoticz and used some scripts to set the temperature while I'm away or at home.
The strange thing is that the Toon keeps going back to 20 degrees. No matter what program (thuis, weg, slapen) I choose and no matter what way I'll use to control it.
The temperature is a fixed temperature (20) and not a program whatsoever.
Does anyone have an idea how to fix this and is it possibible to do a "factory reset" without losing the root option?
mAiden
Re: Toon keeps hopping back to 20 degrees
Post by mAiden »
First of all, check that Domoticz does not set Toon to 20 degrees. Or another program.
It is Excluded that Toon automatically even go back to 20gr. Impossible.
Return to “Toon miscellaneous”
