Black Screen on Putty
I'm am new over here, and started just to Root my Toon.
I hade bought a 3.3V USB cable with the pins..
https://nl.aliexpress.com/item/32901826 ... 4c4d0BL6Ve
so connected this to my toon like the guide wright. Pin 11 is the RXD. Pin 13 is the TXD and 14 is the GRN.
After that i plugged in my usb port from my computer. On device info it's on com3. checkt settings
115200 baud, 8 databits, No parity, 1 stopbit)
and then i plugged in the module for power at the back.. but putty stays black.
maybe i did something wrong?
Re: Black Screen on Putty
Did you put the white one on pin 13 (that is RX on the cable and the TX on the toon) and the green on the pin 11 (TX on the cable and RX on the toon)? If still not working please paste a photo of how you connected it
Yes i have.
And after connected the cables i have plugged in the module
Read the message again, and turn the green and white cable.
So now i cant see the bootup. Thanks for the support.
Can or cant?Ossegek wrote:Read the message again, and turn the green and white cable.
I am in Putty right now.
Almost to the end of the tutorrial.
Ok.
After i pressed the reset button i cat the following screen.
<a href="https://ibb.co/q1RhzKL"><img src="https://i.ibb.co/q1RhzKL/2.png" alt="2" border="0"></a>
Eneco Toon by Quby
eneco-001-245576 login:
But when i follow the Youtube tuttorial i have the setting
Eneco Toon by Quby
eneco-001-245576 login: wdhpc: sending discover
And he is not asking for a password. Where did i do something wrong?
Eneco Toon by Quby
Eneco Toon by Quby
You need to set your root password during rooting
btw, why not use the toonrooter script? It makes it easier for you.
Can i still do this? Because i can't pas the screen from the picture because of the password.TheHogNL wrote:You need to set your root password during rooting
Using the manual rooting guide you set the password during root when you changed the uboot setting to get into the /bin/sh login.
But you can still start the toonrooter script which will root your toon 'again' and set a password for you.
Ok. And for that i have to follow the tutorial with the raspberry pi.TheHogNL wrote:Using the manual rooting guide you set the password during root when you changed the uboot setting to get into the /bin/sh login.
Yes, from here https://github.com/ToonSoftwareCollective/ToonRooter
But did you set the password or not? It's just one easy step and you are done.
TheHogNL wrote:Yes, from here https://github.com/ToonSoftwareCollective/ToonRooter
I think i did not set a password.
Get back where you had the /bin/sh access and change your password in the /etc/passwd fileOssegek wrote:TheHogNL wrote:Yes, from here https://github.com/ToonSoftwareCollective/ToonRooter
You need to put a crypted password in there. Read here how to get a crypted password: viewtopic.php?f=101&t=11230&p=92570&hil ... swd#p92570
