TheHogNL wrote:Did you already enable ZonopToon? Did you connect a zonoptoon kwh meter already?
Please describe your setup a bit more.
The Toon calculates realtime usage by taking the P1 data and the zonoptoon-kwh-production data.
I actually just canceled my toon contract with provider .. so the current Toon + readout is all i have.
The PV installer did not supply me with a "smart" breaker in the breakerbox .. I think that's needed ?
I could connect
https://www.elektramat.nl/emat-dinrail- ... d-gekeurd/ if that allows me to provide the same data ? (think not)
- domoticz with only plugins to "read data" .. the growatt is connected although light on "details"
- the node-red is not doing anything yet..(not feeding into domoticz) and is just a play thing to understand stuff.
I just would like to know if possible to "fake" a toonopzoon kwh thingy (in what format needs it to be put where.. ), and can i activate "solar" data to display ..
Thinking out loud
if the data is stored in location A (on "disk" ) with Zwave software .. and imported by software B from location A and we can alter software B to look at a different location .. its simple to "inject" data using a "cat" + "sed" thingy
if at al possible (think not)
I could also do generated Watt - returned Watt = used Watt and feed that back to the toon from domoticz (if needed/wanted)
I don't expect it to be easy though
and i need to code it ..
so if i need to acces /dev/blabla --> or file x.y.z do magic .. Or because of limitations (i currently not know of ..) or key words to dive into the forum any and all advice/help is appreciated.
I don't know the flow of stuff and here you guys have at least a lot more insight .. that could save me time ..
