Toon App: DoorCamHA
Arcidodo
Toon App: DoorCamHA
Post by Arcidodo »
i edit the app DoorCam to get it working for Home Assistant instead of Domoticz.
create an input_number helper in HA like: input_number.showdoorcamtoon
fill in the configuration menu with your camera, HA server adres and entity_id.
the token is a very long string, so you can edit the file: /mnt/data/tsc/doorcamha_userSettings.json manually to copy/past the token.
i use NodeRed to set the value of the input_number.showdoorcamtoon see screenshot.
Download app:
https://github.com/arcidodo/doorcamha/r ... amha-1.0.0
oepi-loepi
Re: Toon App: DoorCamHA
Post by oepi-loepi »
Nice! Have you also seen the latest modification to the Domoticz Doorcam App? This version also has a selector switch to force 16:9 cam images.
Can we merge the two apps into one maybe? Just an idea.....
oepi-loepi
Toonz wrote:Can we merge the two apps into one maybe? Just an idea.....
Is has all been merged into the doorcam app which is available in the toonstore. Please find the manual in the other doorcam section avialable on this forum.
viewtopic.php?f=99&t=12776#p94165
