PMIX35 / programming modules
JeroenE
Post by JeroenE »
I'm a new Xanura owner, so it might just be me but I have problems with the PMIX35.
I have a test setup consisting of a DAIX12 connected to a lamp and two switches (because I don't have a double switch yet). With the tow switches I can turn the lamp on/off. Dimming also works fine. So this seems to work fine.
The PMIX35 is connected to a PC. The software can see the PMIX35.
However, if I turn on the lamp the PC does not show this in the log file. Also when I try to turn on/off the lamp with the PC this does not work.
The PMIX35 is connected to the same extension cord as the lamp. I have tried both with or without a FM10 plugin filter on the extension cord. Except for a lower "netwerk impedantie" in the Xanura software this did not work.
I tried to program the module with the software (putting the module in programming mode by pushing the program switch for 3 seconds); this did not work.
According to the logfile there are "suspicious echo"'s on the line, but I don't know what that means:
Datum Tijd      Spatie  Data 1  Voltage 1       Ruis Niveau 1   Data 2  Voltage 2       Ruis Niveau 2   Netwerk Impedantie      Status  Echo
02-08-2008 06:18:45     S       AOFF    6879    1249                            12,5    Suspicious      Echo
02-08-2008 06:19:49     S       AON     5155    1249                            12,5    Suspicious      Echo
02-08-2008 06:21:34     S       AON     6449    1249                            7,5     Suspicious      Echo
02-08-2008 06:21:45     S       AOFF    5165    1245                            7,5     Suspicious      Echo
02-08-2008 06:24:02     S       A01     5003    1245    A01     4980    1248    7,5             Echo
02-08-2008 06:24:02     S       APRG    4935    1241    APRG    5002    1240    7,5             Echo
02-08-2008 06:24:03     S       AHRQ    4972    1247    AHRQ    4983    1249    7,5     Suspicious      Echo
02-08-2008 06:25:04     S       APRG    4993    1240    APRG    4976    1243    7,5             Echo
02-08-2008 06:25:04     S       APRG    4988    1246    APRG    5001    1249    7,5             Echo
02-08-2008 06:25:04     S       A01     5001    1235    A01     4985    1249    7,5             Echo
02-08-2008 06:25:05     S       APRG    4940    1249    APRG    4983    1244    7,5             Echo
02-08-2008 06:25:05     S       AHRQ    4975    1249    AHRQ    4991    1238    7,5     Suspicious      Echo
02-08-2008 06:26:07     S       APRG    4992    1246    APRG    4989    1246    7,5             Echo
02-08-2008 06:26:07     S       APRG    4968    1234    APRG    4942    1239    7,5             Echo
02-08-2008 06:26:08     S       A01     4929    1235    A01     4955    1221    7,5             Echo
02-08-2008 06:26:08     S       APRG    4978    1241    APRG    4976    1238    7,5             Echo
02-08-2008 06:26:09     S       AHRQ    4984    1247    AHRQ    5024    1249    7,5     Suspicious      Echo
02-08-2008 06:27:12     S       APRG    4966    1236    APRG    4953    1249    7,5             Echo
02-08-2008 06:27:12     S       APRG    4961    1247    APRG    4950    1247    7,5             Echo
I also tried with a SAIX12 but that module is also not seen by the PMIX35.
Does anyone know what I'm doing wrong or what could be the problem?
Bastiaan
Post by Bastiaan »
Maybe your wire is too short, meaning your signal is too strong?
Did you try lowering the Voltage setting? Tried it on a long distance between de PMIX35 and the units?
JeroenE
Post by JeroenE »
I didn't try a lower voltage setting before, but I did just now. It doesn't make a difference. I haven't tried a longer distance, but I need it to work on a 'short' distance anyway (although not as short as the lamp-wire). The lower voltage setting also doesn't work for the receiving of command's from the module, IOW I still don't see those either. I tried every half volt or so; I also tried a bit with the 60 and 120 degrees setting, but that doesn't help either.
02-08-2008 12:07:55     S       AON     2344    1249                            12,5    Suspicious      Echo
02-08-2008 12:08:24     S       AON     2479    1249                            12,3    Suspicious      Echo
02-08-2008 12:08:33     S       AON     2621    1249                            12,5    Suspicious      Echo
02-08-2008 12:08:39     S       AON     2789    1249                            12,6    Suspicious      Echo
02-08-2008 12:08:47     S       AON     3326    1249                            12,6    Suspicious      Echo
02-08-2008 12:08:56     S       AON     3738    1249                            12,5    Suspicious      Echo
02-08-2008 12:09:04     S       AON     4461    1249                            12,5    Suspicious      Echo
02-08-2008 12:09:09     S       AON     5046    1249                            12,5    Suspicious      Echo
02-08-2008 12:09:17     S       AON     5760    1249                            12,3    Suspicious      Echo
02-08-2008 12:09:26     S       AON     6307    1249                            12,3    Suspicious      Echo
02-08-2008 12:09:32     S       AON     6871    1249                            12,5    Suspicious      Echo
02-08-2008 12:09:58     S       AON     4022    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:05     S       AON     2640    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:11     S       AON     7846    1249                            12,3    Suspicious      Echo
02-08-2008 12:10:18     S       AON     3780    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:25     S       AON     5294    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:29     S       AON     6883    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:33     S       AON     5083    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:40     S       AON     4616    1249                            12,5    Suspicious      Echo
02-08-2008 12:10:45     S       AON     3040    1249                            12,5    Suspicious      Echo
JeroenE
Post by JeroenE »
I tried again today but this time on a very long extension cord to a different wall outlet. This works better. Perhaps the computer is generating to much interference? I'l have to test some more, because it is a bit annoying to have an extension cord through the entire house.
