I have Opentherm Gateway by Nodo shop connected to Brink Renovent HR (ventilation) in stand-alone mode with OTGW firmware version 5.1
I am testing it with otmonitor (TCP IP connection) before connecting to Openhab. I have few Alternative Data Ids defined (AA=70,AA=71,AA=77,AA=80, AA=82, )
I am observing a very strange behavior as follows:
After connecting and putting the gateway mode of the otmonitor (@ 17: 11) it is trying to read MsgID=0 several times over hours:
17:11:39.963327 R00000000 Read-Data Status (MsgID=0): 00000000 00000000
- CH enable: disabled (0)
- DHW enable: disabled (0)
- Cooling enable: disabled (0)
- OTC active: not active (0)
- CH2 enable: disabled (0)
- Summer/winter mode: winter (0)
- DHW blocking: unblocked (0)
19:04:40.271601 BF0000000 Unk-DataId Status (MsgID=0): 00000000 00000000
19:04:40.281941 Command: PR=A
19:04:40.355945 PR: A=OpenTherm Gateway 5.1
19:04:41.187522 R80190000 Read-Data Boiler water temperature (MsgID=25): 0.00
19:04:41.241491 B70190000 Unk-DataId Boiler water temperature (MsgID=25): 0.00
19:04:42.216974 R10010000 Write-Data Control setpoint (MsgID=1): 0.00
19:12:45.640194 R80520000 Read-Data Exhaust inlet temperature (MsgID=82): 0.00
19:12:46.614284 R80520000 Read-Data Exhaust inlet temperature (MsgID=82): 0.00
19:12:47.621675 R80520000 Read-Data Exhaust inlet temperature (MsgID=82): 0.00
19:12:48.621006 R80520000 Read-Data Exhaust inlet temperature (MsgID=82): 0.00
19:22:38.993512 B405214CC Read-Ack Exhaust inlet temperature (MsgID=82): 20.80
19:22:39.880533 R900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
19:22:39.991410 BF00E6400 Unk-DataId Maximum relative modulation level (MsgID=14): 100.00
19:22:40.947075 R80460000 Read-Data Status V/H (MsgID=70): 00000000 00000000
- Ventilation: disabled (0)
- Bypass position: close (0)
20:12:44.971566 R10010000 Write-Data Control setpoint (MsgID=1): 0.00
20:12:45.927355 R10010000 Write-Data Control setpoint (MsgID=1): 0.00
20:12:46.920736 R10010000 Write-Data Control setpoint (MsgID=1): 0.00
20:13:49.833608 OpenTherm Gateway 5.1
20:13:49.844740 Thermostat disconnected
20:13:50.735382 R00000000 Read-Data Status (MsgID=0): 00000000 00000000
Any hints what could be a cause of such a strange behavior?
What shall I investigate further to find the root cause?
