ssl enabled ddns for toon with letsencrypt certificate
gerlag
Post by gerlag »
Hi all, I tried to write an HOWTO to achieve a ssl enabled ddns domain for toon with a valid letsencrypt certificate.
... and I ended up with a script called ddns_client.sh which installs a dyndns client for dynu.com and also acme.sh for creating and automatic updating a let'sencrypt SSL certifcate.
As a result you'll get external password protected SSL (mobile) access for rooted Toon on a -always free- dynu ddns domain.
I published the script on github
in short:
  • Specify username and pasword in Toon for mobile access
  • Create an account on dynu.com and register one of their free third level ddns domains and make a note of Client_id and secret.
  • Create a port forwarding rule on your router
  • After logging in in Toon with putty I can (maybe you can too) install the script online directly from github:
    curl https://raw.githubusercontent.com/gerlag/ddns_for_toon/main/ddns_client_download.sh -O && sh ddns_client_download.sh install
Feel free to test, use or fork it,
Tested on Toon1. I don't have access to a Toon 2. Assume this script could work on Toon 2 too, maybe with minor changes.
Use at your own risk...
Re: ssl enabled ddns for toon with letsencrypt certificate
Post by TheHogNL »
Nice! Didn't try it yet but studied the code.
Acme uses contrab to update the certificate when needed but crontab isn't installed normally on toon1/toon2. So that is one thing to keep in mind before running this script.
And a toon2 doesn't have cron binary in the installed list. That's also why we stopped installing it per default on rooting scripts.
gerlag
Post by gerlag »
The script will install crontab when it's not installed and then it reboots Toon. One of my Toon's 1 had crontab installed, the other (spare) Toon had not.
I didn't know Toon 2 has no crontab at all. Acme.sh needs crontab too, so without it it seems to be a problem to get it running on Toon2.
[edit] I saw that . acme.sh can be installed without cron:
./acme.sh  --install  --nocron
Maybe putting a small script in init.d with an infinite loop that triggers the acme letsencrypt update once a month could do the trick. I'll have a look at it next week.
BTW, I tested the ssl quality, it gets an 'A' from https://www.ssllabs.com/ssltest/ . Not so bad for such a 'light' device as Toon1 is...
Post by TheHogNL »
Think we can add the acme.sh in the tsc script to run each week or so. Let me think about that
gerlag
Post by gerlag »
That's of course a good alternative. In that case, the ddns update script should also be triggered every (half an) hour or so.
oepi-loepi
Post by oepi-loepi »
Zo Berlag. Goed bezig, ik ga hem eens proberen op een toon 2.
In eerste instantie wordt de update-rooted.sh niet gevonden.. misschien een path dingetje. Nu eerst zelf even sh update-rooted.sh -o gegeven en daarna het script gestart.
Zoals aangegeven wordt de cron niet geinstalleerd.
Unknown package 'cron'.
Collected errors:
* opkg_install_cmd: Cannot install package cron.
gerlag
Post by gerlag »
Thanks, oepi loepi, for the confirmation I will look for a nonCron solution. In that case update-rooted.sh is't needed anymore, so that problem will be solved 'automatically'. Maybe next week or so.
gerlag
Post by gerlag »
I made a minor update to my script on github. It appeared that the crontab in toon 1 does not support 'after boot' tasks. Now the script reloads its settings once a day,. That prevents the problem of losing contact after an automatic update of Toon.
Note: script works for Toon1 only!
