I have some issues with rooting a toon1.
My nc on my OS does not have the -N parameter.
(I am using a raspberry Pi Desktop in VMware. It is based on debian10-Buster.)
But apparently the netcat on debian doesn't have the -N parameter that is used in the script so that's where my first issues were.
As a test i did remove the -N parameter in the script, and then the script appears to be going some steps further but I still eventually get stuck.
I have connected the toon1 wired via an ethernet cable. It is seen by my linux and it connects. after modifying the script a bit I do get the message that the toon is found and on what IP it is trying to connect the service center but after that nothing happens anymore.
I think the toon has been completely reset. It is in the 4 step process of initial installation.
Anyone can point me in the right direction?
Tnx!
