Energy saving project
I'm using lot of power,
My goal is to reduce this for about 10%.
About 65% of the power is consumed in standby hours.
see the charts
few systems that run 24h
- Server = 75 Watt
- Ziggo modem + Time Capsule + Asus Giga Swtch +Lava device server + Visonic Pro = 35 Watt
- Camera Server + 2 Camera's +3 Com Giga Switch = 15 watt
- 2 x 2.4Hgz Cams = 16 watt
and some other standard things.
[img]uploaded/Chak/200882211586_power-day.gif[/img]
[img]uploaded/Chak/2008822115838_power-year.gif[/img]
see the charts
- Server = 75 Watt
I found some Old device that consume power when they are idle.
Maxtor NAS box 15 watt ( I'm using this only for backup once per week)
Hp Lasrejet 4L 5 watt (Only printing few pages per month)
Thats 175 KW per year when i can power off
I think you also use the Plugwise modules to trace these unwantig devices?
I have a nice list as well of all the unwanted consumers.
For instance my Samsung digital HD decoder is consuming 15 watt when it's off!! Its even getting hot when its off???
Below you can also see the computer for the kids, its consuming 14.63 watt when it's totally off????
unbelievable that devices like this still are being made.
yep...I'm using Plugwise.
Now a need Homeseer Plugin for switching them off when not in use.
Hope i can do that soon with scripting..
Plugwise will start with development of the plugin for Homeseer later this year.
This will make the product very interesting for Homeseer users.
One of the other candidates my DVB receiver is using 7 watt when idle...thats 61kw per year..[:(!]
[img]uploaded/Chak/2008827225640_plugwise.gif[/img]
Yeah right
I start with one simple event and that is to switch those devices off when the alarm is set to arm.
All those hours I'm saving energy.
I also told Plugwise this week to make a solid Homeseer plugin a priority.
Also the standalone webserver should be finished and have some more functionalities.
If the plugwise Homeseer plugin is available you only have to start the lean & mean Plugwise webserver/controller.
As you know they take our comments serious so I think the do the effort.
Plugwise is making very good products also the price is good 37 euro per plug.
after the latest updates i have no problems with the application and plugwise network.
The script that you are using for turning off all the devices is that something that I also can run from homeseer?
I'm still working on that part, so I'm not switching my Plugwise devices off yet. I only want to switch the devices of combined with my own Home Automation system. If I have more info or got it working I will report.
This is the code they use for switching on there own webserver software:
<body onload="pageInit()">
<div class="title">
<div style="float:left;width:70%">Plugwise Source</div>
<div style="float:right;width:30%;text-align:right" class="smalltext" id="datetime"><%=System.Date%> <%=System.Time%></div>
</div>
<form method="POST" name="panelsForm">
// no items checked
$applianceIds={}
$title="Rooms"
$id="room"
$ckdids=Request.post.containsKey("roomids")?Request.post["roomids"].GetUnique():{}
$list=Plugwise.Rooms
Write System.Blocks["panel.applianceTree"]
$title="Groups"
$id="group"
$ckdids=Request.post.containsKey("groupids")?Request.post["groupids"].GetUnique():{}
$list=Plugwise.Groups
<br>
<input type="hidden" name="cmd">
Switch selected:<br>
<input type="button" value="On" onclick="runCommand(this.form,'switchOn')">
<input type="button" value="Off" onclick="runCommand(this.form,'switchOff')">
</form>
<br>
<br>
<img align="top" border="0" src="/img/pdf_20.png"> <a href="/doc/Plugwise_Source_Template_Engine.pdf" target="_blank">Documentation</a>
</body>
- Snelvuur
at some point, if you have devices that take up kwh's in standby, you can just turn it off if you dont use it. So if you turn off the t.v. , turn of the socket too. Which basicly does the same then what you do with plugwise. Although graphs and stuff is nice , i think i'll order a set too in the future to try it out.. since its zigbee that should still work normally in my house. (given up on xanura for the time being, to much interference from neighbours etc etc)
- Willem4ever
- Global Moderator
how much power can you switch with a circle ?
- Willem4ever
- Global Moderator
that would suffice for most appliances.
would it be feasible/practical to use these devices to switch on/off lights ?
(as an alternative to z-wave / x10 etc.)
Marcel
Marcel
I'm also using the plugs for lights control.
At the moment they have only plugs..in the near future more products will be available.
When compared to the Zwave/X10
More functions
standby killer
Power consumption meter
Secure (also zwave is that)
Soft click
Compact size
2way like xanura (zwave you have to ask the status all the time)
Also the price is better than most zwave device
More functions
standby killer
Soft click
Compact size
Are they planning to build a box for in the meter cabinet.
So you can measure a complete fase or 3 fase.
- Snelvuur
might have a copyright from rfxpower meter ;p
