PMIX35 and noise levels
zyx
Post by zyx »
I'm in the middle of implementing my Xanura setup.
When i was analyzing my network with the PMIX35 i realized that i don't have any reference values to compare to.
I'd like to propose that we all post some values here so we might be able to extract some kind of acceptable values from the results. Before you start flaming me, i did read the PMIX35 manual and i could not find any reference levels in there. The manual only states that impedance my not be lower then 1.9ohm.
What noise and impedance levels do my colleague forum readers have ? :)
Cheers,
Peter
Snelvuur
Post by Snelvuur »
no flames here, but ... do you experience any issues then allready? if not, then there is no need right? :-)
MindBender
Post by MindBender »
I agree that it would still be nice to have a frame of reference here. So if I don't forget it, I will post some of my values here.
zyx
Post by zyx »
No problems here, only finished the first floor of my home just now.
Just curious about other people's values.
Here are my levels:
Impedance = between 7.5 ohms and 12 ohms
Noise = between 0.07 volt and 0.30 volt
Cheers,
Peter
Snelvuur
Post by Snelvuur »
Impedance: 8.1 ohm (always it seems)
noise: 0,06 <-> 0,10 volt
MindBender
Impedance: ~5.5Ohm
noise: <0,05Volt
stefxx
Post by stefxx »
Impedance: 8,6 - 9,2 ohm
noise: 0,05 - 0,09 volt
Antoon
Post by Antoon »
Impedance: 1,3 Ohm
Noise: 0.03 Volt
