OTMonitor v6.5 stops passing commands from MQTT to serial
qjb
Post by qjb »
OTmonitor v6.4 can be controller using MQTT. For instance:
topic 'otgw/actions/ctrlsetpt' message '{"value": 29}'
Sets the CS to 29. The log shows in response:
... Command (via MQTT): CS=29
After upgrading to OTmonitor v6.5 this stopped working. The log no longer shows the command being received.
What am I doing wrong?
Re: OTMonitor v6.5 stops passing commands from MQTT to serial
You're not doing anything wrong. This is bug #23. It has been fixed in the latest version of the software. But there has not been a release that includes the fix yet. Fortunately, binaries with the fix have automatically been built by github actions.
qjb
Post by qjb »
Ah. Thanks a lot.
