Visonic and remote panel
Moderators: Rene, Willem4ever
Noel
Post by Noel »
Okay. It looks like I've managed to setup the Visonic pro
I have set it up that when in "home" mode, the office (2nd floor) and living room (ground floor) are protected, and the bed room(s) on the 1st floor are not.
Now I would like to add an option to arm and disarm the Visonic Pro from the 1st floor.
Till now I've been using the "Sleutelhanger" to do this, but I would like to replace this with "fixed" unit.
What would be the best unit to do this?
Would it be the MCM-140 - Draadloos bedieningspaneel or the MKP-150 - Tweeweg draadloos bedieningspaneel
I love the "just push the button" on the "Sleutelhanger" to arm/disarm the alarm.
Do the two Bedieningspanelen also have this option, or do I need to enter the arm/disarm codes?
<h6>Anyone interested in time travel meet me here last Thursday!!
Download todays latest spoken weather by the WiFi bot (in Dutch) here (MP3).</h6>
I have both panels
Arming can be done with just one push and disarming needs the code of course otherwise I can do it for you [:D]
Noel
Post by Noel »
Thanks for the info.
In that case I might stay with the "Sleutelhanger", and build something nice around it and fix it to the wall.
I really do not want to push codes at 06:00 in the morning to disarm the alarm.
Yeah right [:)]
So when i come into your house uninvited, all i have to do is look for "something nice" on the wall [:D]
Noel
Post by Noel »
The thing is that you can not get at it from any other floor wihtout triggering the alarm.
For the Pro version you can also use the new key with two way communication.
I have no extra interface only the keys.
They work fine for me.
Noel
Post by Noel »
Chak. A bit off topic, but does your Homeseer (and RFXcom) see the keys?
yes..and I have build special events to do more when a key is received.
For every key one event
from the script other events will run
see the script
[img]uploaded/Chak/20081124235519_keyfob.gif[/img]
@Wifi: My RFXCOM receiver is in the garage which is behind te house. Signals from my Visonic sensors are received perfect but signals from my 2-way keyfob are once in a while lost.
Noel
Post by Noel »
Looks nice Chak.
What do you use as "Trigger" for the Visonic keyfob?
Device Status Change or Device Value Change?
In case of the "Status Change". What option are you using the the Status?
If you are using the "Value Change", what are your settings?
At the moment I'm using the Device Vaue Change, but this is I think not the way that the event should be triggered.
Noel
Post by Noel »
@Rene,
Till now I have no problems with the keyfob.
The main unit is located in the hallway. Not far away from using the keyfob.
@wifi see the picture..
[img]uploaded/Chak/2008112512333_ScreenShot001.gif[/img]
Noel
Post by Noel »
Hmmm. I do not have the option "Becomes .. Any Value" under the trigger "Device Value Change"!
strange...did you first selected the keyfob in device?
Noel
Post by Noel »
Wow.. A reboot does do wonders :-)
All okay now! (I have the same options as you Chak)
