This device can be controlled with HTTP commands as well so it can be easily integrated in your HA system.
I will going to use this device on bwired and fllow up on this topic.
<b>Dutch seller:</b>
http://www.pimzos.nl/shop/aviosys/ipsen ... deluxe.php
<b>Thanks to:</b>
http://www.automatedhome.co.uk/Reviews/ ... eview.html
<b>Extra info:</b>
http://www.digidave.co.uk/jshop/product ... markmccall
<b>Manual:</b>
http://support.digidave.co.uk/downloads/9212dmanual.pdf
<b>General Specification:</b>
- Embedded web server. No PC needed for the unit to operate.
- 10/100Mbps Fast Ethernet Network Access (RJ45 Jack)
- With 8DI & 8DO: Direct control relay output (DO) and detection of digital input (DI)
- 8 Set Sensor (8 DI) #65533; Default 4 Set Source mode (Dry - Voltage Input) and & 4 Set Sink mode (Wet- Resistance Input). Mode is switchable.
- 8 Set Controllers (8 DO) #65533; Default 4 Set Normal Open (NO) & 4 Sets Normal Close (NC). Mode is switchable.
- Network protocols supported: HTTP, DDNS, SNMP, DHCP, Virtual and Dynamic IP.
- Support RS232 to control.
- Timer Schedule - pre-set the time to turn power on / off.
- Security code identification and Hardware reset function.
- Easy installation, setup and supports online upgrade.
- Individual LED indicates switch-working status.
- Safe, durable, non-electric leakage and anti-flammable design.
- Polar protection even if connected to contrary port
- Digital inputs provide de-bouncing function
- Update firmware by the TCP/IP network.
- SDK (Software Development Kits) and Webpage Command Provided.
- Embedded "WATCH DOG" - by request
- Support GPRS control and sense with WAP or WIFI mobile phones
- Support SMTP: Send IP address by E-mail as log in and send e-mail as detecting sensor trigger.
- 10 ms maximum operating time
<b>Control Specification:</b>
- 8x outputs
- 240 VAC, 60 VDC maximum switching voltage
- 12 A, AC/DC maximum switching current
<b>Sensor Specification:</b>
- 8x inputs
- Source mode (Voltage input):
ON: 4V - 24V
OFF: 0V - 3V
Examples: voltage sensor such as smoke, gas, density, infrared, motion detectors... Valve like high-temperature, high-pressure, automatic control valve#65533;
- Sink Mode (Resistance input):
ON: 0-200 ohm resistance input
OFF: 500 ohm - infinity resistance input
Examples: resistance sensors such as door/window sensors.
