Homeseer update topic
Misschien handig als we dit als homeseer update/beta versie topic gebruiken? Update's /Beta komen van de lopende band.
Laatste officieel beschikbare versie
2.3.0.9 (Beta)
- HST Status update
- Startup problemen met CTX35 (systeem kan vastlopen tijdens opstart)
Voor een totaal overzicht zie
http://board.homeseer.com/showthread.ph ... 533&page=3
2.3.0.9 (Beta)
- HST Status update
Versie 2.3.0.16 is beschikbaar
Heeft ook gelijk voor een startup error in Prontronic plugin gezorgd..maar het werkt nog wel.
Initializing interface: Prontonic->Public member 'link' on type 'i' not found
# Errors generated by plug-in web page links were causing portions of the "Plug-Ins" link page to not be generated - this has been addressed.
# Modified FormatAction to display (Missing Device) when a device is not present for the "Remove Delayed Actions" action - will add more missing device placeholders for other actions in the future.
# Fixed an issue with the log file pruning not able to handle month abbreviations in the log file names that are more than 3 characters.
# Fixed voice recognition error for command strings of the format (|) missing a command
# Fixed email handing when MIME parts are not complete
# Fixed formatting of the log entry when setting a wake-up interval on a Z-Wave device to 24 hours or more.
# Fixed a bug with Z-Wave Optomization where it would check for the best remote interface (HS Pro, multiple interfaces) even though it was not told to (not set to (Auto))
# Fixed hs.SetDeviceString to trigger callbacks after device string is actually changed.
# Changed logging of device commands to only log commands, for devices that do not exist, for commands issued to addresses in the X-10 range.
# Fixed an issue where the control panel, X-10 command, does not process multiple addresses like it says it will - only does the first one - now fixed.
# HSM100 sub-devices are changed again - if NO LOG is set, then they do not log but they still get queried for their values, but if they are HIDDEN then they will not be queried for their values.
Via de updater is versie 2.3.0.19 beschikbaar , maar de site is erg druk.
gr Ruud
Enver kan jij aangeven wat er veranderd (gefixed) is? Ik weet niet waar ik die info kan vinden.
gr Ruud
Ik heb geen verder informatie gevonden..weet wel dat vanuit Homeseer iedereen met het verhelpen van de bugs bezig is dat zelf HSTouch even moet wachten.
weet wel dat een aantal plugins wat problemen hebben met de laatste versie .16
Grappig.. ik heb een update gedaan, maar in mijn portal (jon00 webpage) blijft het versienummer op 2.3.0.16 staan. De updater geeft wel aan dat het 2.3.0.19 is.
Tja, er is nog veel te fixen met HS 2.3. Ik zit al lang met een Doonetwork probleem, ik heb geen config pagina meer. Wordt aan gewerkt (hoop ik)...
Veranderingen in versie .19
* Fixed event names not transferring properly on Cooper controller replication.
* Fixed an issue with Cooper controller replication resulting in duplicate events in HomeSeer being created.
* Saved Z-Wave scenes will now default to a ramp rate of "device default" when they are newly created.
Doonetwork problem heb ik ook
Ik heb ook een melding van gemaakt..wachten is nu op Homeseer dat ze met een oplossing komen.
mijn hoop was dat .19 probleem zou verhelpen.
@Chak: Ik draai nog steeds 2.3.0.0. Hoe doet de Plugwise plugin het onder de laatste versie?
Plugin works fine under 23.0.0.19
gr ruud
gr ruud
@Rene,
Plugwise plugin draait zonder problemen.
HSTouch versie 0.18 en even later is versie 0.19 beschikbaar gekomen
Morgen maar even naar kijken
Verbeteringen zien er goed uit oa op PocketPC versie van de client
