Do you need always a sperfilter?
So yes, wil it the Holec Sperfilter fix into a ABB box?
Sperfilter Xanura
Sperfilter Xanura
Normaly you have a DIN rail in your Fusebox. On the DIN rail you can click a Filter.
It is a advice from Xanura to have one if you have one phase powerline. It prevents data leaving and entering your house.
But I tought it is realy needed (3 times) when you have 3 phase installation.
Sperfilter Xanura
I now that it is one phase installation.
But i have to see the fusebox inside to see of the filter wil fix, i hope so!
I thing its better to buy one so that there are no data is leaving and incoming my home.
Sperfilter Xanura
Normaly all new Fuseboxes are with a DIN rail, Do you have Fuses with a switch, and it's a normale residential than it's 99% sure it has a DIN rail.
Sperfilter Xanura
The filter can be mounted in any installation that uses modern circuit breakers (schakelautomaten) placed on a 'din rail'. The filter cannot be placed inside an old type fusebox with screw type fuses. I expect the ABB box to use a DIN rails, so space permitting you would be able to fit one without any problems.
You do want to use one, as it isolates your electrical system from the rest of the powergrid. That avoids any external signals interfering with the X10 modules, and more importantly it improves attenuation of the X10 signals in your home.
