X10 address error
drmacchi
X10 address error
Post by drmacchi »
Hi all a new strange thing i need to solve!
A single address (A3) doesn't work anymore, the situation is:
CTX35 + Homeseer
-ctx35 can not control A3, not with HS neither using ctx35 terminal
- that x10 module setted on A3 works if setted something else (a4 , a5...)
-other x10 modules setted on A3 don't work
-if i change wall ploug nothing changes
- the same module setted on A3 WORKS if using x10-remote (3 different types remote!) or SC9000.
So it doesn't work when using pc and software.
Suggestions?
Cheers. lorenzo
b_weijenberg
X10 address error
Post by b_weijenberg »
I don't know the CTX35 but is there any intelligence (macros) in the CTX35 that blocks A3 or translates it to another address or action?
drmacchi
X10 address error
Post by drmacchi »
No Bert, and it has been working until some days ago.
MindBender
X10 address error
Post by MindBender »
Perhaps another module is at fault and interfering with address A3. Try switching off cirquits (groups) to eliminate the problem. You could also try if it works if you use a module and the CTX35 on an isolated cirquit, behind a filter.
