Hi All
I have replaced tree 240V halogeen lights with tree 240V LED lights on one AW10 X10 module.
After this installation I have problems with my X10 modules.
When I switch “ON” the LED lights, I can’t switch them “OFF” remotely.
Also, some of the module nearby won’t work anymore.
When I switch OFF the module manually, the system works fine.
It looks like the LED lights are interfering with X10 modules.
I was wandering if anyone has the same problem and maybe a solution to this problem.
Thanks in advance.[:)]
Hans
http://www.chamiri.nl
LED ligths problem with AW10
Hi Hans,
Really late reply, but my guess would be that your transformer for the LED-lights emits some sort of interference on your powerline.
A filter should take care of that for you.
//Markus
//Markus
Hi Markus,
The LED's are the 240Volt type, so I don't use a transformer.
Thanks anyway.
Hans
Hans Hov
Thanks anyway.
Hans
Hans Hov
You might not have an external transformer, but the Led lamp has an integrated electronic transformer and that may be causing the problem. Try placing a filter.
- Snelvuur
You got a webpage for the leds? I presume the leds also costs less when compared to halogeen right? (kwh wise)
// Erik
http://www.binkey.nl
// Erik
Hi Erik,
I ordered the LED lights in the HMK-shop.
www.hmk.nl
The shop is not very professional and I waited a long time for my order.
Greetings Hans,
www.hmk.nl
Greetings Hans,
