mct234
Moderators: Rene, Willem4ever
Ruud
mct234
Post by Ruud »
What is the x10 code for the keyfob mct 234.
I have done some settings in the powermax pro but?????
m.v.g. Ruud
DMB
mct234
Post by DMB »
Ruud,
The MCT234 doesn't has a X10 code.
You can define a X10 device for the * key.
Arming and disarming the powermax can also be sent to a X10 device.
On the housecode + 1 on adress 1 (e.g. housecode of the powermax = B, then C1) a X10 command is sent when the powermax is in alarm.
This is how it works for a powermax. Maybe it's different for the powermax pro.
DMB
Ruud
mct234
Post by Ruud »
DMB,
I have define "
L1= "volledige inschakeling"
L2="gedeeltelijke inschakeling"
M1 is automatic asign for when there is a alarm.
But how do i asign a x10 code to the *button?
gr Ruud
DMB
mct234
Post by DMB »
Ruud,
In the system programming menu set "Aux knop" on PGM/X-10.
Define the time in the field "PGM & X-10 tijd", e.g. 30 seconden.
In the X-10 instellingen menu set on one of the lines e.g. 7 a Ja in the field "Zender".
When pushing the x (AUX knop) on the keyfob a X10 ON command is send to L7. After 30 seconds a X10 OFF is sent to L7.
If you choose Latch in the field "PGM & X10 tijd" the ON will be sent when pressing the * and the second time you press the * a OFF will be sent. (Toggle)
This works for the powermax.
Difficult to combinate dutch and english.
DMB
