Schedules are stored in the Circles but does anyone know a way to retrieve and upload them using a script? It's not mentioned in the Source Template.
I would like to be able to retrieve schedules or at least the status of a schedule (present or not) from the Circles, to make a judgement if the power has been cut off either form powerfailure (which I had last evening!) or because a circle has been unplugged and plugged in again.
And in that case also be able to upload/update the schedule to the Circle again, and again through a HTML based script so I can do that from a remote location (internet).
I know I could monitor a dedicated switched-off Circle and then assume there was a powerfailure if the status is switched-on again as mentioned in another post, but this will tell me nothing if some Circle has been removed shortly and placed back again.
The Source also only seems to be able to upload, but is not checking if a schedule is still present (in force) after a powerfailure?
Schedule stored in Circle
- Starting Member
For as far as I now it's only possible to send schedules with the standard software.
